Ana içeriğe geç
DigiTech RP70 Input/Output ¼” Ports Replacement
Neye ihtiyacın var
  1. DigiTech RP70 Input/Output ¼” Ports  Replacement, Motherboard: adım 1, 2 resimden 1. DigiTech RP70 Input/Output ¼” Ports  Replacement, Motherboard: adım 1, 2 resimden 2.
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. DigiTech RP70 Input/Output ¼” Ports  Replacement: adım 2, 2 resimden 1. DigiTech RP70 Input/Output ¼” Ports  Replacement: adım 2, 2 resimden 2.
    • Remove the back panel to expose the motherboard.
  3. DigiTech RP70 Input/Output ¼” Ports  Replacement: adım 3, 1 resimden 1.
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. DigiTech RP70 Input/Output ¼” Ports  Replacement: adım 4, 1 resimden 1.
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
  5. DigiTech RP70 Input/Output ¼” Ports  Replacement, Input/Output ¼” Ports: adım 5, 2 resimden 1. DigiTech RP70 Input/Output ¼” Ports  Replacement, Input/Output ¼” Ports: adım 5, 2 resimden 2.
    • Desolder the back of the motherboard where the damaged input/output port is located.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 404
