Ana içeriğe geç
Digiland 10.1'' DL1016 Power Button Replacement
Neye ihtiyacın var
  1. Dikkatli ol: adımlar 1-2 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
    Digiland 10.1'' DL1016 Power Button Replacement, Digiland 10.1'' DL1016 Remove Backing: adım 1, 2 resimden 1. Digiland 10.1'' DL1016 Power Button Replacement, Digiland 10.1'' DL1016 Remove Backing: adım 1, 2 resimden 2.
    • Use an opening pick and an opening tool to pry the backing off the back of the tablet.
    • You may need some force when doing this and if needed use a metal spudger.
  2. Digiland 10.1'' DL1016 Power Button Replacement: adım 2, 2 resimden 1. Digiland 10.1'' DL1016 Power Button Replacement: adım 2, 2 resimden 2.
    • Gently lift the backing off.
  3. Dikkatli ol: adım 3 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
    Digiland 10.1'' DL1016 Power Button Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: adım 3, 2 resimden 1. Digiland 10.1'' DL1016 Power Button Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: adım 3, 2 resimden 2.
    • Gently pull the wiring back.
    • You may need to use a metal spudger to lift the wire connector off the back of the screen.
  4. Digiland 10.1'' DL1016 Power Button Replacement, Power Button: adım 4, 1 resimden 1.
    • Disconnect the black cable off the motherboard.
    • Remove the four 1.5mm Phillips #000 screws from the motherboard.
  5. Digiland 10.1'' DL1016 Power Button Replacement: adım 5, 2 resimden 1. Digiland 10.1'' DL1016 Power Button Replacement: adım 5, 2 resimden 2.
    • Make sure the ribbon cables are free or unconnected so the motherboard is able to be moved.
    • Use a metal spudger to slide underneath the motherboard and push it up so it's unstuck from the tablet.
    • Lift up the motherboard and place it somewhere that is clean and kept safe.
Sonuç
CRISTIAN RAMIREZ
85 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team S1-G2, Saknee Fall 2019 Gateway, Team S1-G2, Saknee Fall 2019 üyesi
GCC-SAKNEE-F19S1G2
4 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
I want to know if ebay cheap 1 count usb charge port. Is okay to buy 4 This tablet. It is $3 or less & is all I need, I think. Just broke my tablet way worse on sloppy job of screen replacement , but it look ok. You see lint hair, etc underneath when screen off at an angle close uo is all & ruined power button area ceazy glue, etc mess I have to press down hard with something & now on top of all, the charger chord at same time plys charge lose all of a sudden so it isnt really charging or a hassle & if it is it turns off while playing on a game. etc. Now it is not even turning on. Just tries, but doesn't. At least b4 it was. I took it apart to see the charge port . Good thing its not a cable type & can easily replace for cheaoer then one too. I has wrong battery reading or diff on screen off then on have 2opush down, but charge port lose. I don’t know if replacing will fix it or it has other issue when I messed up the power button. I need 2 try the port till I can buy other tablet. If I had not broke it been okay. Lesson learned
Lily R - Yanıt
I had more to say just a bit, but I didn’t copy to paste it on 2nd post & I wish I had. S I'll n e went over chrts I just back arrow backspace deleted. Oh well. Nvm.
Lily R - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 650
