Giriş
To replace the Digiland DL1168A battery you will need an opening tool. Be sure to be careful. The glue on the battery is sticky and hard to get off.
Neye ihtiyacın var
Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
Desolder the three positive, negative, and neutral red, black, and white wires from the motherboard that are connected to the battery.
2 farklı kişi bu kılavuzu tamamladı.
