Ana içeriğe geç
Digiland DL1168A Rear Case Replacement
Neye ihtiyacın var
  1. Digiland DL1168A Rear Case Replacement, Rear Case: adım 1, 1 resimden 1.
    • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  2. Digiland DL1168A Rear Case Replacement: adım 2, 2 resimden 1. Digiland DL1168A Rear Case Replacement: adım 2, 2 resimden 2.
    • Carefully lift back panel away from the body of the device.
    • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
  3. Digiland DL1168A Rear Case Replacement: adım 3, 2 resimden 1. Digiland DL1168A Rear Case Replacement: adım 3, 2 resimden 2.
    • Desolder the four wires connecting the rear case to the motherboard.
    • Disconnect the wires from the motherboard.
    • Remove the rear case from the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 111
