Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Insert spudger in the slot below the micro SD card
With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
Remove ALL the yellow tape securing the gold colored ZIF (Zero insertion force) connector and the battery. Discard or save the tape if you would like.
To unclip the connector. Go under the black tab with a spudger or finger nail and simply lift up.
Locate the bundled cable connector and disconnect it by simply pulling it gently with your hands or using a spudger.
Use prying tools to carefully break the adhesive under the battery
Now that you have removed the battery, proceed to removing the two 3.51mm screws with your Phillips #00 Screwdriver.
Carefully lift the casing and pull back the tape along with the soldered wire.
Now that the casing is off, proceed to the motherboard and solder off the cable. The area that needs soldering will be labled "SPK"
