Ana içeriğe geç
Digital2 D2-912 Speaker Replacement
Neye ihtiyacın var
  1. Digital2 D2-912 Speaker Replacement, External Cover: adım 1, 1 resimden 1.
    • Remove the two Phillips #00 screws from the bottom of the case.
  2. Digital2 D2-912 Speaker Replacement: adım 2, 2 resimden 1. Digital2 D2-912 Speaker Replacement: adım 2, 2 resimden 2.
    • Wedge the opening tool in the space between the back and the front of the tablet.
    • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
    • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
  3. Digital2 D2-912 Speaker Replacement, Speaker: adım 3, 1 resimden 1.
    • Pull the speaker away from the tablet. It should easily come off, as it is held on with a magnet.
  4. Digital2 D2-912 Speaker Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Desoldering Pump
    $3.99
    Satın Al
    • Remove the wires from the motherboard using a soldering iron and a solder sucker.
    • Refer to ifixit's soldering guide to remove the solder on the wires.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lindsay Richardson
394 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Harley Fall 2015 IUPUI, Team 1-1, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S1G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 148
