Ana içeriğe geç
Giriş
This guide will help users replace damaged or malfunctioning internal dual speakers on the Digitech XC-5206 Bluetooth speaker. Please refer to troubleshooting page before beginning replacement guide steps.
  1. Remove the front panel by forcefully placing the flat edge of the spudger in between the panel and the plastic housing. Angle the spudger and use your fingers to pry the panel off.
    • Remove the front panel by forcefully placing the flat edge of the spudger in between the panel and the plastic housing.
    • Angle the spudger and use your fingers to pry the panel off.
    • You may need to use extra force.
  2. Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion. Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face. OR grab ahold of the silver tab to pull the speaker face out. This may require force.
    • Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
    • Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
    • OR grab ahold of the silver tab to pull the speaker face out. This may require force.
  3. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Unscrew the eight 10mm screws closest to the center of the speakers by spinning a Phillips screwdriver with a PH2 bit in a counterclockwise motion. Push speaker bulbs forward and out of slot.
    • Unscrew the eight 10mm screws closest to the center of the speakers by spinning a Phillips screwdriver with a PH2 bit in a counterclockwise motion.
    • Push speaker bulbs forward and out of slot.
  5. Remove green (left) and red (right) wired connection to speaker bulb using a soldering station. Remove green (left) and red (right) wired connection to speaker bulb using a soldering station.
    • Remove green (left) and red (right) wired connection to speaker bulb using a soldering station.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 3
Son 30 Gün: 5
Her zaman: 90
