Direct-Pull Cantilever Brake ("V-Brake") Maintenance
Giriş
1. adıma gitBrakes slow your bike down when you pull on the brake lever on the handlebar. The brake calipers are connected to the brake levers by a cable that squeezes the brake-pads that are attached to the brake calipers. When the brake pads contact the rims they slow down the rim of the wheel, slowing down the bike.
Neye ihtiyacın var
Aletler
Squeeze the calipers together, and remove the brake cable.
Tighten/loosen the tension adjustment screws on each the caliper arm to adjust the resting distance of each brake pad, so that each pad is equally distant from the rim. Tightening the screw will shift the caliper outward from the bike, loosening it will shift it inward.
Tighten/loosen the brake adjuster on the handle bars such that when you clamp down on the brakes, the brake lever stops before hitting the handle bar. This will set the distance between the brake pads and the rim.
Tighten the lock nut on the brake adjuster to permanently set its position.
Bir başkası bu kılavuzu tamamladı.
