Ana içeriğe geç
Dirt Devil Gator Motor Replacement
Neye ihtiyacın var
    1. Dirt Devil Gator Motor Replacement, Motor: adım 1, 1 resimden 1.
      • Press the button found at the top of the vacuum to separate the suction cup and the motor halves.
      FixBot'a Sor
      Yorum Ekle
    2. Dirt Devil Gator Motor Replacement: adım 2, 3 resimden 1. Dirt Devil Gator Motor Replacement: adım 2, 3 resimden 2. Dirt Devil Gator Motor Replacement: adım 2, 3 resimden 3.
      • Pull apart the two halves to obtain the back half and set the front half aside
      FixBot'a Sor
      Yorum Ekle
    3. Dirt Devil Gator Motor Replacement: adım 3, 3 resimden 1. Dirt Devil Gator Motor Replacement: adım 3, 3 resimden 2. Dirt Devil Gator Motor Replacement: adım 3, 3 resimden 3.
      • Unscrew each of the 13 mm screws with the micro screwdriver.
      • Once unscrewed, pull the case of the Dirt Devil Gator apart.
      FixBot'a Sor
      Yorum Ekle
    4. Dirt Devil Gator Motor Replacement: adım 4, 3 resimden 1. Dirt Devil Gator Motor Replacement: adım 4, 3 resimden 2. Dirt Devil Gator Motor Replacement: adım 4, 3 resimden 3.
      • Pull out the grey switch and circuit board from its slot in the red case.
      • Remove all of the wires from the vacuum to where only the battery and wires are left.
      • Firmly pull out the battery and motor assembly. The circuit board and wires will remain attached.
      FixBot'a Sor
      Yorum Ekle
    5. Dirt Devil Gator Motor Replacement: adım 5, 1 resimden 1.
      • Remove the motor from the Dirt Devil Gator exterior by pulling slightly on the white socket.
      • Replace it with a new motor by fitting the motor back into its socket.
      • Be cautious when handling the batteries and wires.
      • Keep the grey on-off switch in the "off" position to ensure a quick reassembly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 35
Her zaman: 926
