Ana içeriğe geç
Dirt Devil Scorpion Quick Flip Circuit Board Replacement
Neye ihtiyacın var
  1. Dirt Devil Scorpion Quick Flip Circuit Board Replacement, Circuit Board: adım 1, 1 resimden 1.
    • Push the button on the left-hand side of the handle.
    • Remove the filter holder from the main body.
  2. Dirt Devil Scorpion Quick Flip Circuit Board Replacement: adım 2, 2 resimden 1. Dirt Devil Scorpion Quick Flip Circuit Board Replacement: adım 2, 2 resimden 2.
    • Remove the first two 4 mm screws using a Phillips #1 Screwdriver.
    • Remove the last four 4 mm screws using a Phillips #1 Screwdriver.
    • Carefully take the device a part.
  3. Dirt Devil Scorpion Quick Flip Circuit Board Replacement: adım 3, 2 resimden 1. Dirt Devil Scorpion Quick Flip Circuit Board Replacement: adım 3, 2 resimden 2.
    • Identify the circuit board located in the inside of the handle.
    • Remove the gray switch located on top of the circuit board.
    • Using utility scissors, cut the wires 1/2 inch away from the circuit board.
  4. Dirt Devil Scorpion Quick Flip Circuit Board Replacement: adım 4, 2 resimden 1. Dirt Devil Scorpion Quick Flip Circuit Board Replacement: adım 4, 2 resimden 2.
    • Solder the new circuit board to the existing wires.
    • Using electrical tape or heat shrink tubing, cover the soldered area.
    • Place the new circuit board into the correct spot inside the handle.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with the soldering process.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 132
