Ana içeriğe geç
Dirt Devil Scorpion Quick Flip Power Cord Replacement
Neye ihtiyacın var
  1. Dirt Devil Scorpion Quick Flip Power Cord Replacement, Power Cord: adım 1, 1 resimden 1.
    • While holding the device by the handle, press the button on the left-hand side of the vacuum handle in order to release the nozzle from the body.
  2. Dirt Devil Scorpion Quick Flip Power Cord Replacement: adım 2, 2 resimden 1. Dirt Devil Scorpion Quick Flip Power Cord Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 Screwdriver, remove all six of the 4 mm screws holding the shell together.
  3. Dirt Devil Scorpion Quick Flip Power Cord Replacement: adım 3, 1 resimden 1.
    • Using utility scissors, cut the black and white cables approximately an inch and a half above where they connect to the faulty power cord.
  4. Dirt Devil Scorpion Quick Flip Power Cord Replacement: adım 4, 1 resimden 1.
    • Using a soldering iron, fuse the black and white cables from the new power cord to where the previous cord was cut away.
    • Using electrical tape, cover the exposed area.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with the soldering process.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 282
