Ana içeriğe geç
Disassembling HP Photosmart c3180 Top Panel
Neye ihtiyacın var
  1. Disassembling HP Photosmart c3180 Top Panel, Top Panel of HP Photosmart c3180 printer: adım 1, 2 resimden 1. Disassembling HP Photosmart c3180 Top Panel, Top Panel of HP Photosmart c3180 printer: adım 1, 2 resimden 2.
    • Before disassembling your printer, be sure that the printer has been unplugged to avoid any risk of injury.
    • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Remove the two T10 12mm Torx screws from the left side panel.
  2. Disassembling HP Photosmart c3180 Top Panel: adım 2, 2 resimden 1. Disassembling HP Photosmart c3180 Top Panel: adım 2, 2 resimden 2.
    • Firmly pull the the back of the side panel until it separates from the body of the printer.
    • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
  3. Disassembling HP Photosmart c3180 Top Panel: adım 3, 2 resimden 1. Disassembling HP Photosmart c3180 Top Panel: adım 3, 2 resimden 2.
    • Rotate the printer 90 degrees clockwise.
    • Grasp the paper tray and rotate it down.
    • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
  4. Disassembling HP Photosmart c3180 Top Panel: adım 4, 2 resimden 1. Disassembling HP Photosmart c3180 Top Panel: adım 4, 2 resimden 2.
    • Remove the two T10 12 mm Torx screws.
    • Grasp both sides of the side panel and pull it forward to remove the panel.
  5. Disassembling HP Photosmart c3180 Top Panel: adım 5, 2 resimden 1. Disassembling HP Photosmart c3180 Top Panel: adım 5, 2 resimden 2.
    • Rotate the printer 90 degrees counter clockwise.
    • Lift the scanner lid to expose the scanner glass.
  6. Disassembling HP Photosmart c3180 Top Panel: adım 6, 1 resimden 1.
    • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
  7. Disassembling HP Photosmart c3180 Top Panel: adım 7, 2 resimden 1. Disassembling HP Photosmart c3180 Top Panel: adım 7, 2 resimden 2.
    • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Remove the front panel by grasping its front and pulling away from the printer.
  8. Disassembling HP Photosmart c3180 Top Panel: adım 8, 2 resimden 1. Disassembling HP Photosmart c3180 Top Panel: adım 8, 2 resimden 2.
    • Remove the cable connecting the top panel of the printer to the power button assembly.
  9. Disassembling HP Photosmart c3180 Top Panel: adım 9, 1 resimden 1.
    • Carefully lift the top panel of the printer away from the printer body.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Jim
1.623 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-30, Maness Fall 2011 Cal Poly, Team 20-30, Maness Fall 2011 üyesi
CPSU-MANESS-F11S20G30
4 Üyeler
25 adet Kılavuz yazıldı
1Rehber Yorum
Thanks... Now I'know how clean
Diogo Pires Nunes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 49
Her zaman: 6,837
