Ana içeriğe geç
Disassembling HP Photosmart c3180 Top Panel
Neye ihtiyacın var
  1. Disassembling HP Photosmart c3180 Top Panel, Top Panel of HP Photosmart c3180 printer: adım 1, 2 resimden 1. Disassembling HP Photosmart c3180 Top Panel, Top Panel of HP Photosmart c3180 printer: adım 1, 2 resimden 2.
    • Before disassembling your printer, be sure that the printer has been unplugged to avoid any risk of injury.
    • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Remove the two T10 12mm Torx screws from the left side panel.
  2. Disassembling HP Photosmart c3180 Top Panel: adım 2, 2 resimden 1. Disassembling HP Photosmart c3180 Top Panel: adım 2, 2 resimden 2.
    • Firmly pull the the back of the side panel until it separates from the body of the printer.
    • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
  3. Disassembling HP Photosmart c3180 Top Panel: adım 3, 2 resimden 1. Disassembling HP Photosmart c3180 Top Panel: adım 3, 2 resimden 2.
    • Rotate the printer 90 degrees clockwise.
    • Grasp the paper tray and rotate it down.
    • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
  4. Disassembling HP Photosmart c3180 Top Panel: adım 4, 2 resimden 1. Disassembling HP Photosmart c3180 Top Panel: adım 4, 2 resimden 2.
    • Remove the two T10 12 mm Torx screws.
    • Grasp both sides of the side panel and pull it forward to remove the panel.
  5. Disassembling HP Photosmart c3180 Top Panel: adım 5, 2 resimden 1. Disassembling HP Photosmart c3180 Top Panel: adım 5, 2 resimden 2.
    • Rotate the printer 90 degrees counter clockwise.
    • Lift the scanner lid to expose the scanner glass.
  6. Disassembling HP Photosmart c3180 Top Panel: adım 6, 1 resimden 1.
    • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
  7. Disassembling HP Photosmart c3180 Top Panel: adım 7, 2 resimden 1. Disassembling HP Photosmart c3180 Top Panel: adım 7, 2 resimden 2.
    • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Remove the front panel by grasping its front and pulling away from the printer.
    Änderung des Textes: die kleine Lasche verriegelt die kleine Frontblende: mit leichtem Druck Richtung “rechte Druckerseite entriegeln, gleichzeitig jene Blende nach vorn lösen.
    Garofalo - Yanıt
  8. Disassembling HP Photosmart c3180 Top Panel: adım 8, 2 resimden 1. Disassembling HP Photosmart c3180 Top Panel: adım 8, 2 resimden 2.
    • Remove the cable connecting the top panel of the printer to the power button assembly.
  9. Disassembling HP Photosmart c3180 Top Panel: adım 9, 1 resimden 1.
    • Carefully lift the top panel of the printer away from the printer body.
    nur die dünne weiße Abdeckung, die graue bleibt noch; zuerst hinten anheben, vorn ist mittig eine Nase zu lösen.
    Garofalo - Yanıt
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Jim
1.623 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-30, Maness Fall 2011 Cal Poly, Team 20-30, Maness Fall 2011 üyesi
CPSU-MANESS-F11S20G30
4 Üyeler
25 adet Kılavuz yazıldı
1Rehber Yorum
Thanks... Now I'know how clean
Diogo Pires Nunes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 48
Her zaman: 6,827
