Ana içeriğe geç
Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,
Neye ihtiyacın var
  1. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, First look: adım 1, 3 resimden 1. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, First look: adım 1, 3 resimden 2. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, First look: adım 1, 3 resimden 3.
    • To open the laptop, first you have to unscrew the back-screws.
    • 1. remove the plastic/rubber caps
    • 2. unscrew the 12 screws.
    • ATTN: Do not forget!
    • unplug the laptop from power source & remove the batery
    • unscrew the 3 tiny screws behind the battery
    • keep the lid closed till later on
    Is this the whole of the foot or just the cap on top of it. I removed the cap and there is a tiny hole but no visible screw. If I take off the foot, they will probably be damaged in the process.
    Steve Marples - Yanıt
  2. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Back - HDD, WIFI card,: adım 2, 3 resimden 1. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Back - HDD, WIFI card,: adım 2, 3 resimden 2. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Back - HDD, WIFI card,: adım 2, 3 resimden 3.
    • Here you have some details regarding the back of the laptop. After you got read of the back cover you can access the following:
    • 1. WIFI card - Easy to change / replace There are two cables attached to it. Remove them, then unscrew the screw that holds the card in place and lift gently up - DONE.
    • 2. HDD / SSD. All you have to do is grab and pull the ribbon (as in photo). There are a few extra steps to change it.
  3. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Removing the keyboard: adım 3, 3 resimden 1. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Removing the keyboard: adım 3, 3 resimden 2. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Removing the keyboard: adım 3, 3 resimden 3.
    • Now to remove or change the keyboard
    • 1. Insert gently the cutte (or other sharp tool) and press towards the screen & flip up slowly.
    • To remove it completely unplug the two connectors.
    • After removing the keyboard you find:
    • 1.ECO Button
    • 2. Sound
    • 3. Power button
    • 4. Mouse pad
    I just wanted to say that on my P875-S7102 (which is a very similar build), the keyboard is stuck in there pretty good’n’tight! There is a bit of a cutout at the bottom right corner (as seen when sitting at the laptop normally) and if you can get in there, you can begin to pry it out. It takes a fair bit of force, it’ll feel like you’re almost going to break the keyboard, but it really does just pop out. Just keep going along the front and you can release all the clips one by one.
    Carsten Dreesbach - Yanıt
  4. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Removing the screws to open the case: adım 4, 3 resimden 1. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Removing the screws to open the case: adım 4, 3 resimden 2. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Removing the screws to open the case: adım 4, 3 resimden 3.
    • remove all the screws as shown in the images.
  5. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Splitting the case an upper side (under theh keyboard): adım 5, 3 resimden 1. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Splitting the case an upper side (under theh keyboard): adım 5, 3 resimden 2. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Splitting the case an upper side (under theh keyboard): adım 5, 3 resimden 3.
    • Opening the case is easy, follow the steps as shown.
    • To change / remove the speakers remove the screws.
    • To change / remove the Eco/3D button or power button, yo have to remove first the speakers.
  6. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Change / remove speakers and buttons (Power and Eco/3D): adım 6, 3 resimden 1. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Change / remove speakers and buttons (Power and Eco/3D): adım 6, 3 resimden 2. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Change / remove speakers and buttons (Power and Eco/3D): adım 6, 3 resimden 3.
    • Still more steps to come :), probably till 12... so min 6 more.
    • I will show you how to repair a broken hinge (plastic broken) - easy.
  7. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, CPU fan cable remove: adım 7, 1 resimden 1.
    • Remove the fan cable
    • If you want to change the CPU fan, there are 2 screws that you have to remove (picture)
  8. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Start repairing the broken hinge: adım 8, 3 resimden 1. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Start repairing the broken hinge: adım 8, 3 resimden 2. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Start repairing the broken hinge: adım 8, 3 resimden 3.
    • Broken hinge, detailed photo
  9. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Repairing the broken hinge [detailed photo]: adım 9, 3 resimden 1. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Repairing the broken hinge [detailed photo]: adım 9, 3 resimden 2. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Repairing the broken hinge [detailed photo]: adım 9, 3 resimden 3.
    • Repairing the broken hinge [detailed photo]
  10. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Repairing the broken hinge [detailed photo] (2): adım 10, 3 resimden 1. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Repairing the broken hinge [detailed photo] (2): adım 10, 3 resimden 2. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Repairing the broken hinge [detailed photo] (2): adım 10, 3 resimden 3.
    • do not forget about the grey cable attached on the bottom side.
    • When reattaching the cable, put some thermal paste on the contact (gray cable)
  11. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Fixing the hinge with plastic dowel pin: adım 11, 3 resimden 1. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Fixing the hinge with plastic dowel pin: adım 11, 3 resimden 2. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Fixing the hinge with plastic dowel pin: adım 11, 3 resimden 3.
    • insert the plastic dowel pin from bottom-up and level it inside at the same height with other screw holes
  12. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Detailed img for inserting the plastic dowel pin: adım 12, 3 resimden 1. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Detailed img for inserting the plastic dowel pin: adım 12, 3 resimden 2. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Detailed img for inserting the plastic dowel pin: adım 12, 3 resimden 3.
    • follow the pics
  13. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,: adım 13, 2 resimden 1. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,: adım 13, 2 resimden 2.
    • add some thermalpaste to the gray cable
  14. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Outside & inside finishing: adım 14, 3 resimden 1. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Outside & inside finishing: adım 14, 3 resimden 2. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Outside & inside finishing: adım 14, 3 resimden 3.
    • Cut the excess plastic from the dowel pin
    • Put some super-glue to fix it in place
  15. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Outside & inside finishing (2): adım 15, 3 resimden 1. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Outside & inside finishing (2): adım 15, 3 resimden 2. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Outside & inside finishing (2): adım 15, 3 resimden 3.
    • I have glued some foam near the speakers in order to protect the aerea
  16. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Final touches: adım 16, 3 resimden 1. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Final touches: adım 16, 3 resimden 2. Disassembling Laptop Toshiba Satellite P855 P850 plus Hinge FIX,, Final touches: adım 16, 3 resimden 3.
    • Glue inside the plastic dowel pin
    • Use thermal paste to fix the gray cable (i have used silver paste)
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Oscar SOTAN
420 İtibar
1 Kılavuz yazıldı
2 Yorum
I have a slipped HDMI port. At which step would I be able to access that?
Preston Ruottinen - Yanıt
My Toshibe C55T-B5349, I want to replace the "lid assembly" which includes the screen and digitizer. Can you give the steps? Thanks
RAM SAINATH - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 57
Her zaman: 35,656
