Ana içeriğe geç
Disassembling Nokia 3395 Screen
Neye ihtiyacın var
    1. Disassembling Nokia 3395 Screen, Back Case: adım 1, 3 resimden 1. Disassembling Nokia 3395 Screen, Back Case: adım 1, 3 resimden 2. Disassembling Nokia 3395 Screen, Back Case: adım 1, 3 resimden 3.
      • Turn the phone off.
      • Hold the phone, and gently press the white button located at the bottom of the phone.
      • While pressing the button, slide the back plate upwards, opening the plate.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling Nokia 3395 Screen, Battery: adım 2, 2 resimden 1. Disassembling Nokia 3395 Screen, Battery: adım 2, 2 resimden 2.
      • Locate grey buttons beneath battery (shown).
      • Spread buttons simultaneously away from each other and the battery will pop out.
      • Remove battery from phone.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling Nokia 3395 Screen, Front Case: adım 3, 2 resimden 1. Disassembling Nokia 3395 Screen, Front Case: adım 3, 2 resimden 2.
      • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
      • Flip over the device, and pry the faceplate away.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling Nokia 3395 Screen, Screen: adım 4, 2 resimden 1. Disassembling Nokia 3395 Screen, Screen: adım 4, 2 resimden 2.
      • Remove six T6 screws.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling Nokia 3395 Screen: adım 5, 2 resimden 1. Disassembling Nokia 3395 Screen: adım 5, 2 resimden 2.
      • Insert spudger between screen assembly and phone body.
      • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Nico Lee
83 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 30-41, Garner Spring 2010 Cal Poly, Team 30-41, Garner Spring 2010 üyesi
CPSU-GARNER-S10S30G41
4 Üyeler
72 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 24
Son 30 gün: 54
Her zaman: 2,943
