Ana içeriğe geç
Disassembling Samsung ATIV Smart PC 500T Backplate
Neye ihtiyacın var
  1. Disassembling Samsung ATIV Smart PC 500T Backplate, Backplate: adım 1, 2 resimden 1. Disassembling Samsung ATIV Smart PC 500T Backplate, Backplate: adım 1, 2 resimden 2.
    • Remove the stylus from the device.
    • Place the device screen-up on a hard surface, like a table.
  2. Disassembling Samsung ATIV Smart PC 500T Backplate: adım 2, 3 resimden 1. Disassembling Samsung ATIV Smart PC 500T Backplate: adım 2, 3 resimden 2. Disassembling Samsung ATIV Smart PC 500T Backplate: adım 2, 3 resimden 3.
    • Insert a plastic pry tool or opening pick between the glass and plastic case.
    • Work your way around the plastic edge, unclipping the backplate.
    • Once the clips are loosened, remove the backplate. Some force may be necessary.
    • Though you may need to use force, be careful of the pry tool slipping and hurting you!
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Crystal Dinh
1.026 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 6-6, Williams Fall 2015 Baylor, Team 6-6, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S6G6
3 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
Samsung tablet xe500t1c partition missing problem
waheed - Yanıt
Partition do not show
x drive show
waheed - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 3,720
