Ana içeriğe geç
Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part
Neye ihtiyacın var
  1. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part, Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: adım 1, 3 resimden 1. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part, Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: adım 1, 3 resimden 2. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part, Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: adım 1, 3 resimden 3.
    • Begin by removing all six #00 screws holding the outer chassis together.
    • Remember to keep track of all screws as they are small and very easy to lose
  2. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: adım 2, 3 resimden 1. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: adım 2, 3 resimden 2. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: adım 2, 3 resimden 3.
    • At this point most of the parts in the camera should be free moving.
    • Take note of the small free moving flap near the battery port seen in the first of the three photos.
    • Now pry apart the top and bottom shell of the case.
  3. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: adım 3, 3 resimden 1. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: adım 3, 3 resimden 2. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: adım 3, 3 resimden 3.
    • Remove the two ribbon cables holding the LCD screen in place. Pull them directly out of the port they are plugged into.
    • Take care not to tear these ribbons as they are the communication network that your screen uses to operate.
    • Now that your LCD screen is detached you can pull it apart from the rest of the camera.
    There’s an extra small part with some metal on it. But i cannot figure out where it came from?
    Brayan - Yanıt
  4. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: adım 4, 3 resimden 1. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: adım 4, 3 resimden 2. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: adım 4, 3 resimden 3.
    • The inner lining frame has an orange ribbon cable (circled in the image) that needs to be detached before it can be safely removed.
    • Carefully remove the inner frame lining as it can be fragile.
    There’s a really small price I cannot figure out where it came from? Can anyone help?
    Brayan - Yanıt
  5. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: adım 5, 2 resimden 1. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: adım 5, 2 resimden 2.
    • After the LCD screen has been removed there is a black metal plate that can be pulled off revealing the motherboard and the lens.
  6. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: adım 6, 2 resimden 1. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: adım 6, 2 resimden 2.
    • To separate the motherboard from the lens there are two ribbon cables that need to be pulled out of their ports.
  7. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: adım 7, 2 resimden 1. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: adım 7, 2 resimden 2.
    • Finally to separate the motherboard from the base skeleton frame, one last silver screw and one ribbon cable need to be removed.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
5 Yorum
So what about the other parts not in your photos that fall ?
The bracket around the speaker and this little white part that fell out as soon as I lifted the back cover a little? can you please give more info
Kat - Yanıt
I'm also finding where was the white parts located. It seems that without this part, wx80 works well. If you found its location, please give me hint. Thanks.
Chung-Suh Ku -
Maybe this helps for the location of the white part: https://www.quora.com/What-does-the-insi...
Christian Urban - Yanıt
This is not complete disassembly pics. Not at all. This is half the steps.
Mayur Panghaal - Yanıt
Huh?
How about the sensor? How do I clean the sensor?
jim dandy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 2,298
