Ana içeriğe geç
Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover
iDeleted
iDeleted ve 10 diğer katkıda bulunanlar
En son December 8, 2020 tarihinde güncellendi
5 dakika
Kolay
Topluluk-Katkılı Kılavuz
Removing the front cover is a necessary first step in disassembling the camera in order to repair or replace any internal parts.
Neye ihtiyacın var
Aletler
  1. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Battery: adım 1, 2 resimden 1. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Battery: adım 1, 2 resimden 2.
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: adım 2, 1 resimden 1.
    • Remove the battery from the door that you opened in the previous step.
  3. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: adım 3, 3 resimden 1. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: adım 3, 3 resimden 2. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: adım 3, 3 resimden 3.
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: adım 4, 2 resimden 1. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: adım 4, 2 resimden 2.
    • Use hands to gently pry the front casing away from the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
iDeleted
2.101 İtibar
39 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 2,636
