Disassembling Translucent Rubber Flashlight Battery Power Component
Giriş
1. adıma gitDisassembly of Translucent Flashlight for Analysis or Replacement Parts
Remove light mechanism from body containing battery. Twist light bulb (red circle) counterclockwise while holding base of flashlight (black circle).
Using the freed tip, detach the bottom of the metal switch connected to the spring of the grounded/negative end where the AA batteries are located (circle).
Push metal end into square hole so clip detaches from battery spring (circle). Pull out rest of clip avoiding spring, so metal switch freed from body.
The switch mechanism disassembly removes the button attached to the lid (red circle) from the grooves (blue circle) containing the switch components.
Next, remove the spring first and then metallic, grooved pressure plate which contained the spring (red circle) using hand.
Finally, remove metal connections of battery switch by lifting holes (red circle) off containment piece.
5 farklı kişi bu kılavuzu tamamladı.
