Disassembling Wii Balance Board
Neye ihtiyacın var
Aletler
Unscrew these #1 Philips screws, and leave them in the plastic foot holders.
The ADC and Logic board contains:
Bluetooth module
Power button connector
Battery and sync button connector
Strain gauge wheatstone bridge connections
The topmost connection for each of the four bridge connections is the ground; relative to this, the two middle connections should be at 1.2 VDC, and the bottom should be at 2.7 VDC
15 farklı kişi bu kılavuzu tamamladı.
5Kılavuz Yorumları
Can I take out the battery box without removing the bottom?
No, you can't. You will have to follow this procedure completely.
is there schematics for the power pcb
