Ana içeriğe geç
Diswoe Switch-01 Battery Replacement
Neye ihtiyacın var
  1. Diswoe Switch-01 Battery Replacement, Battery: adım 1, 3 resimden 1. Diswoe Switch-01 Battery Replacement, Battery: adım 1, 3 resimden 2. Diswoe Switch-01 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Use a Phillips screwdriver to remove the two screws at the bottom of the hand grips.
    • Remove the handgrips from the controller.
    FixBot'a Sor
    Yorum Ekle
  2. Diswoe Switch-01 Battery Replacement: adım 2, 3 resimden 1. Diswoe Switch-01 Battery Replacement: adım 2, 3 resimden 2. Diswoe Switch-01 Battery Replacement: adım 2, 3 resimden 3.
    • Turn the controller over so the bottom is facing up.
    • Use a Phillips screwdriver to remove the five screws from the back case.
    FixBot'a Sor
    Yorum Ekle
  3. Diswoe Switch-01 Battery Replacement: adım 3, 3 resimden 1. Diswoe Switch-01 Battery Replacement: adım 3, 3 resimden 2. Diswoe Switch-01 Battery Replacement: adım 3, 3 resimden 3.
    • Use both hands to carefully remove the back cover.
    • For help removing the back cover, use a spudger to pry along the seam between the top and bottom case.
    • Don't pull the back cover off quickly or forcefully as the wires that are connected are easy to break.
    FixBot'a Sor
    Yorum Ekle
  4. Diswoe Switch-01 Battery Replacement: adım 4, 3 resimden 1. Diswoe Switch-01 Battery Replacement: adım 4, 3 resimden 2. Diswoe Switch-01 Battery Replacement: adım 4, 3 resimden 3.
    • Push on alternating sides of the battery connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • Additionally, if the previous step didn’t work, use the arms of a pair of sharp tweezers to gently push the connector out of its socket by inserting them into the cutouts.
    • If you're having trouble, try rocking the connector side-to-side to loosen it.
    • To reconnect the cable, insert the connector into its socket and push on the edges until it's fully seated
    FixBot'a Sor
    Yorum Ekle
  5. Diswoe Switch-01 Battery Replacement: adım 5, 2 resimden 1. Diswoe Switch-01 Battery Replacement: adım 5, 2 resimden 2.
    • Remove the battery from the main circuit board.
    • The battery is held in place by sticky foam. If you aren't able to remove it easily by hand, use a spudger to gently loosen the adhesive and then remove the battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 farklı kişi bu kılavuzu tamamladı.
Ekip
CSU Los Angeles, Team 2-3, Kershman Fall 2024 CSU Los Angeles, Team 2-3, Kershman Fall 2024 üyesi
CSULA-KERSHMAN-F24S2G3
4 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 538
