Dome Ceiling Light Bulb Replacement
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
Find the dim or blinking light in your household that needs to be changed.
Gather the material that you will be using like shoes, rags, and plastic gloves.
Put new light to the side to avoid mixing up with old light.
Using the rubber sole of the shoe bump the dome lid in a clockwise direction to loosen the dome lid
Now using your hand, remove the dome lid by turning you wrist in a clockwise direction.
Clean the top and bottom of the dome light to insure there wont be any spots in light when put back.
Safely pull out light after you have turned off the light switch. Also keep in mind where the holes are when you remove the old light.
Place in new light and make sure that you have it in firmly to avoid any accident.
Turn on the light to make sure that the new light is not defective and works properly.
Place the cover back on the light and twist counter clockwise as much as you can.
Using the shoe tighten the light until it doesn't move anymore. We don't want the light to fall out sudden and cause injury.
once the light has been replaced and the dome is placed back properly all you gotta do is turn on the lights once more to make sure its working.
