Ana içeriğe geç
Dragon Touch A1x Plus Speakers Replacement
Neye ihtiyacın var
  1. Dragon Touch A1x Plus Speakers Replacement, Battery: adım 1, 1 resimden 1.
    • Insert the plastic opening tool between the white back cover and black front over.
  2. Dragon Touch A1x Plus Speakers Replacement: adım 2, 2 resimden 1. Dragon Touch A1x Plus Speakers Replacement: adım 2, 2 resimden 2.
    • Slide the plastic opening tool along the edgeof the device until back cover is detached and remove the cover.
    • You may need to pry the back cover off using the opening tool while moving it along the edge.
  3. Dragon Touch A1x Plus Speakers Replacement: adım 3, 1 resimden 1.
    • Remove the yellow tape holding the battery to the device using your fingers or plastic opening tool if necessary.
  4. Dragon Touch A1x Plus Speakers Replacement: adım 4, 1 resimden 1.
    • Use the hair dryer to melt the glue holding the battery to the device.
    • Be careful not to overheat the battery as it could cause the battery to combust.
  5. Dragon Touch A1x Plus Speakers Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Insert the plastic card under the battery and use it to remove the battery from the device.
    • Be careful not to deform the battery.
  6. Dragon Touch A1x Plus Speakers Replacement: adım 6, 2 resimden 1. Dragon Touch A1x Plus Speakers Replacement: adım 6, 2 resimden 2.
    • Desolder the red and black wires connecting the battery to the motherboard and remove the battery.
  7. Dragon Touch A1x Plus Speakers Replacement, Speakers: adım 7, 3 resimden 1. Dragon Touch A1x Plus Speakers Replacement, Speakers: adım 7, 3 resimden 2. Dragon Touch A1x Plus Speakers Replacement, Speakers: adım 7, 3 resimden 3.
    • Desolder the red and black wires connecting each speaker to the motherboard.
Sonuç
Josh Null
313 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S5-G5, Baechle Spring 2018 IUPUI, Team S5-G5, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S5G5
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 217
