Ana içeriğe geç
Drawstring Bag Tab Replacement
Neye ihtiyacın var
  1. Drawstring Bag Tab Replacement, Drawstring Bag Tab: adım 1, 3 resimden 1. Drawstring Bag Tab Replacement, Drawstring Bag Tab: adım 1, 3 resimden 2. Drawstring Bag Tab Replacement, Drawstring Bag Tab: adım 1, 3 resimden 3.
    • Using your pen and ruler, draw two strips of 3.5" x 0.5" pieces of cloth.
    • Cut those two strips with your scissors.
    FixBot'a Sor
    Yorum Ekle
  2. Drawstring Bag Tab Replacement: adım 2, 1 resimden 1.
    • Align your two strips back to back.
    • Use two sewing pins to hold the strips in place for easy alignment during the sewing process.
    • Carefully handle the pins to avoid accidental punctures or injury. Use a thimble if needed.
    FixBot'a Sor
    Yorum Ekle
  3. Drawstring Bag Tab Replacement: adım 3, 3 resimden 1. Drawstring Bag Tab Replacement: adım 3, 3 resimden 2. Drawstring Bag Tab Replacement: adım 3, 3 resimden 3.
    • Using your thread and sewing needle, sew along the long edge in a straight line using a straight stitch.
    • Use a seam allowance of 1/8"
    • Repeat on the other side.
    • Carefully handle the needle to avoid accidental punctures or injury. Use a thimble if neede.
    FixBot'a Sor
    Yorum Ekle
  4. Drawstring Bag Tab Replacement: adım 4, 2 resimden 1. Drawstring Bag Tab Replacement: adım 4, 2 resimden 2.
    • Fold your strip around the cord to your drawstring bag to create a loop.
    FixBot'a Sor
    Yorum Ekle
  5. Drawstring Bag Tab Replacement: adım 5, 3 resimden 1. Drawstring Bag Tab Replacement: adım 5, 3 resimden 2. Drawstring Bag Tab Replacement: adım 5, 3 resimden 3.
    • Using the whipstitch technique, sew the two ends together.
    • Carefully handle the needle to avoid accidental punctures or injury. Use a thimble if needed.
    FixBot'a Sor
    Yorum Ekle
  6. Drawstring Bag Tab Replacement: adım 6, 3 resimden 1. Drawstring Bag Tab Replacement: adım 6, 3 resimden 2. Drawstring Bag Tab Replacement: adım 6, 3 resimden 3.
    • Take the sewn ends and insert them 1/4" into the ripped hole where the original tab was.
    FixBot'a Sor
    Yorum Ekle
  7. Drawstring Bag Tab Replacement: adım 7, 3 resimden 1. Drawstring Bag Tab Replacement: adım 7, 3 resimden 2. Drawstring Bag Tab Replacement: adım 7, 3 resimden 3.
    • Align the fabric with the seam line.
    • Using the whipstitch technique, sew it to the bag from the outside ensuring the stitches are along the seam.
    FixBot'a Sor
    Yorum Ekle
  8. Drawstring Bag Tab Replacement: adım 8, 2 resimden 1. Drawstring Bag Tab Replacement: adım 8, 2 resimden 2.
    • Now you have a working drawstring bag!
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
Ava Overton
157 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 3-1, Andersen Winter 2025 UC Davis, Team 3-1, Andersen Winter 2025 üyesi
UCD-ANDERSEN-W25S3G1
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 16
Son 30 gün: 45
Her zaman: 565
