Ana içeriğe geç
Dreamax DMX-ST7A Battery Replacement
Neye ihtiyacın var
  1. Dreamax DMX-ST7A Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Position the tablet so the ports and screws are facing you.
  2. Dreamax DMX-ST7A Battery Replacement: adım 2, 1 resimden 1.
    • Remove the two 2.5mm screws using the Phillips #00 precision screwdriver.
  3. Dreamax DMX-ST7A Battery Replacement: adım 3, 2 resimden 1. Dreamax DMX-ST7A Battery Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool to assist in removing the back cover.
  4. Dreamax DMX-ST7A Battery Replacement: adım 4, 1 resimden 1.
    • Upon removing the back cover position the tablet as seen in the picture.
  5. Dreamax DMX-ST7A Battery Replacement, Battery: adım 5, 2 resimden 1. Dreamax DMX-ST7A Battery Replacement, Battery: adım 5, 2 resimden 2.
    • Remove any tape that might be holding the wires in place.
  6. Dreamax DMX-ST7A Battery Replacement: adım 6, 3 resimden 1. Dreamax DMX-ST7A Battery Replacement: adım 6, 3 resimden 2. Dreamax DMX-ST7A Battery Replacement: adım 6, 3 resimden 3.
    • Remove the black and gold tab connecting the battery to the tablet's frame.
  7. Dreamax DMX-ST7A Battery Replacement: adım 7, 1 resimden 1.
    • Remove the the one red and two black wires that connect the battery to the motherboard.
  8. Dreamax DMX-ST7A Battery Replacement: adım 8, 2 resimden 1. Dreamax DMX-ST7A Battery Replacement: adım 8, 2 resimden 2.
    • Remove the battery from the tablet.
  9. Dreamax DMX-ST7A Battery Replacement: adım 9, 3 resimden 1. Dreamax DMX-ST7A Battery Replacement: adım 9, 3 resimden 2. Dreamax DMX-ST7A Battery Replacement: adım 9, 3 resimden 3.
Sonuç
Stacey Mattila
543 İtibar
5 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-4, Lauer Spring 2015 Michigan Tech, Team 1-4, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G4
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 450
