Ana içeriğe geç
Dreamax DMX-ST7A Motherboard Replacement
Neye ihtiyacın var
  1. Dreamax DMX-ST7A Motherboard Replacement, Back Cover: adım 1, 1 resimden 1.
    • Position the tablet so the ports and screws are facing you.
  2. Dreamax DMX-ST7A Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the two 2.5mm screws using the Phillips #00 precision screwdriver.
  3. Dreamax DMX-ST7A Motherboard Replacement: adım 3, 2 resimden 1. Dreamax DMX-ST7A Motherboard Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool to assist in removing the back cover.
  4. Dreamax DMX-ST7A Motherboard Replacement: adım 4, 1 resimden 1.
    • Upon removing the back cover position the tablet as seen in the picture.
  5. Dreamax DMX-ST7A Motherboard Replacement, Motherboard: adım 5, 2 resimden 1. Dreamax DMX-ST7A Motherboard Replacement, Motherboard: adım 5, 2 resimden 2.
    • Lift the black bars to expose the data strips.
    • Remove the data strips.
  6. Dreamax DMX-ST7A Motherboard Replacement: adım 6, 2 resimden 1. Dreamax DMX-ST7A Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the three 2.5mm screws using the Phillips #00 precision screwdriver that is holding the motherboard in place.
  7. Dreamax DMX-ST7A Motherboard Replacement: adım 7, 2 resimden 1. Dreamax DMX-ST7A Motherboard Replacement: adım 7, 2 resimden 2.
    • Remove the three wires connected to the battery along with the speaker wires from the motherboard. Then remove the motherboard from the tablet.
  8. Dreamax DMX-ST7A Motherboard Replacement: adım 8, 2 resimden 1. Dreamax DMX-ST7A Motherboard Replacement: adım 8, 2 resimden 2.
    • Install the new motherboard by soldering the speaker wires and the battery wires in their intended location. For additional soldering instructions please view this page: How To Solder and Desolder Connections
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stacey Mattila
543 İtibar
5 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-4, Lauer Spring 2015 Michigan Tech, Team 1-4, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G4
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 321
