Ana içeriğe geç
Dremel MultiPro 395 Casing Replacement
Neye ihtiyacın var
  1. Dremel MultiPro 395 Casing Replacement, Casing: adım 1, 2 resimden 1. Dremel MultiPro 395 Casing Replacement, Casing: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the blue caps located on either side of the MultiPro, using a 3 mm flathead screwdriver.
  2. Dremel MultiPro 395 Casing Replacement: adım 2, 2 resimden 1. Dremel MultiPro 395 Casing Replacement: adım 2, 2 resimden 2.
    • Carefully remove the carbon brushes attached at the end of the springs by gently pulling on the springs using your hands.
  3. Dremel MultiPro 395 Casing Replacement: adım 3, 2 resimden 1. Dremel MultiPro 395 Casing Replacement: adım 3, 2 resimden 2.
    • Pull one side of the hanger up and then pull away from the Multipro until the other side can be pulled out.
  4. Dremel MultiPro 395 Casing Replacement: adım 4, 3 resimden 1. Dremel MultiPro 395 Casing Replacement: adım 4, 3 resimden 2. Dremel MultiPro 395 Casing Replacement: adım 4, 3 resimden 3.
    • Remove the 4 screws located on the bottom of the Multipro with a T15 screwdriver.
  5. Dremel MultiPro 395 Casing Replacement: adım 5, 3 resimden 1. Dremel MultiPro 395 Casing Replacement: adım 5, 3 resimden 2. Dremel MultiPro 395 Casing Replacement: adım 5, 3 resimden 3.
    • Hold down the collet lock, remove the chuck cap from the top of the Multipro by screwing counterclockwise.
  6. Dremel MultiPro 395 Casing Replacement: adım 6, 3 resimden 1. Dremel MultiPro 395 Casing Replacement: adım 6, 3 resimden 2. Dremel MultiPro 395 Casing Replacement: adım 6, 3 resimden 3.
    • Remove the black housing cap from the Multipro located directly below the chuck cap.
    There are 2 more Torx screws under the housing cap on my model 395. I haven't figured out what size screws they are yet, but they're smaller than the other 4 Torx screws in the case.
    Richard Klein - Yanıt
  7. Dremel MultiPro 395 Casing Replacement: adım 7, 3 resimden 1. Dremel MultiPro 395 Casing Replacement: adım 7, 3 resimden 2. Dremel MultiPro 395 Casing Replacement: adım 7, 3 resimden 3.
    • Pull the bottom side of the casing up to remove it.
  8. Dremel MultiPro 395 Casing Replacement: adım 8, 3 resimden 1. Dremel MultiPro 395 Casing Replacement: adım 8, 3 resimden 2. Dremel MultiPro 395 Casing Replacement: adım 8, 3 resimden 3.
    • Gently lift the motor shaft out of the Multipro.
  9. Dremel MultiPro 395 Casing Replacement: adım 9, 3 resimden 1. Dremel MultiPro 395 Casing Replacement: adım 9, 3 resimden 2. Dremel MultiPro 395 Casing Replacement: adım 9, 3 resimden 3.
    • Pull the lock pin and its casing out of the other side of the Multipro case.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
A link to parts is always nice,
bari - Yanıt
Yay! Got my old 395 warrior back to working condition! Many thanks!
Eduardo Capocchi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 2,299
