Ana içeriğe geç
Drill Master Heat Gun Power Switch Replacement
Neye ihtiyacın var
  1. Drill Master Heat Gun Power Switch Replacement, Power Switch: adım 1, 1 resimden 1.
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
    FixBot'a Sor
    Yorum Ekle
  2. Drill Master Heat Gun Power Switch Replacement: adım 2, 1 resimden 1.
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
    FixBot'a Sor
    Yorum Ekle
  3. Drill Master Heat Gun Power Switch Replacement: adım 3, 3 resimden 1. Drill Master Heat Gun Power Switch Replacement: adım 3, 3 resimden 2. Drill Master Heat Gun Power Switch Replacement: adım 3, 3 resimden 3.
    • Remove the barrel casing on either end by twisting and pulling each side off.
    FixBot'a Sor
    Yorum Ekle
  4. Drill Master Heat Gun Power Switch Replacement: adım 4, 1 resimden 1.
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
    FixBot'a Sor
    Yorum Ekle
  5. Drill Master Heat Gun Power Switch Replacement: adım 5, 1 resimden 1.
    • Loosen four screws on the wire connector using the flathead 2.5 screwdriver.
    • Screws do not come out of connector.
    FixBot'a Sor
    Yorum Ekle
  6. Drill Master Heat Gun Power Switch Replacement: adım 6, 1 resimden 1.
    • Squeeze the tabs on either side of the power switch to remove from the casing.
    FixBot'a Sor
    Yorum Ekle
  7. Drill Master Heat Gun Power Switch Replacement: adım 7, 2 resimden 1. Drill Master Heat Gun Power Switch Replacement: adım 7, 2 resimden 2.
    • Remove the black, plastic wire protectors from the end of the power switch.
    FixBot'a Sor
    Yorum Ekle
  8. Drill Master Heat Gun Power Switch Replacement: adım 8, 1 resimden 1.
    • Use soldering iron to remove the electrical wiring from the power switch. To replace the power switch, solder the new switch onto the wires.
    • Heating the soldering metal will allow you to pull off the electrical wiring.
    • For a brush-up on proper soldering, check out How to Solder and Desolder Connections.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 55
Her zaman: 3,941
