Ana içeriğe geç
Dual presta and schrader valve bicycle pump head Gaskets Replacement
Neye ihtiyacın var
  1. Dual presta and schrader valve bicycle pump head Gaskets Replacement, Gaskets: adım 1, 3 resimden 1. Dual presta and schrader valve bicycle pump head Gaskets Replacement, Gaskets: adım 1, 3 resimden 2. Dual presta and schrader valve bicycle pump head Gaskets Replacement, Gaskets: adım 1, 3 resimden 3.
    • It's probably easier to work on the head when it is separate from the pump, so unscrew the cover on the hose at the pump head. You may need to use pliers to get enough grip.
  2. Dual presta and schrader valve bicycle pump head Gaskets Replacement: adım 2, 1 resimden 1.
    • Pull to remove the hose
  3. Dual presta and schrader valve bicycle pump head Gaskets Replacement: adım 3, 1 resimden 1.
    • Remove this pin however you prefer- hammer it out with a drift or other somewhat pointy object, press it out, whatever. Sorry, no pictures, you shouldn't try what I did, even if there was photographic evidence.
    • At first glance, it looked like a rivet or peened over head, so I tried to grind the head off of it. After grinding it down by a couple of millimeters from each end, it became clear that it was a pressed in pin, and not peened or riveted. So, learn from my mistake and do not try to grind it like I did.
  4. Dual presta and schrader valve bicycle pump head Gaskets Replacement: adım 4, 3 resimden 1. Dual presta and schrader valve bicycle pump head Gaskets Replacement: adım 4, 3 resimden 2. Dual presta and schrader valve bicycle pump head Gaskets Replacement: adım 4, 3 resimden 3.
    • After the pin has been removed, the lever easily comes out
    • Next, use another pokey tool (pen, matchstick, small screwdriver, whatever) to push through either valve hole and push the rest of the internals out
    • These are some of the internals
  5. Dual presta and schrader valve bicycle pump head Gaskets Replacement: adım 5, 2 resimden 1. Dual presta and schrader valve bicycle pump head Gaskets Replacement: adım 5, 2 resimden 2.
    • Using your same pokey tool, push the gaskets out by pushing the tool along the side of each valve hole
    • These are all the parts of the pump head, including the pin that's been missing from previous pictures. Note the rubber ball that was hiding between two other pieces. Do not lose it or the pump will not be able to automatically switch between valves
  6. Dual presta and schrader valve bicycle pump head Gaskets Replacement: adım 6, 3 resimden 1. Dual presta and schrader valve bicycle pump head Gaskets Replacement: adım 6, 3 resimden 2. Dual presta and schrader valve bicycle pump head Gaskets Replacement: adım 6, 3 resimden 3.
    • These are the gaskets that have probably worn down. They are identical, but facing opposite directions. The bottom is for the presta valve, and the smaller hole wears down for it. The top gasket is for the schrader valve, and the larger diameter wears down on that one.
    • Switch the gaskets around while flipping them over, or just replace with new gaskets. As mentioned previously, these gaskets may be common among many different types of pump heads. Next push the gaskets into the pump head
    • Put the other pieces in the pump head ("reassembly is the reverse of disassembly"), making sure the rubber ball is captured between the other two pieces.
  7. Dual presta and schrader valve bicycle pump head Gaskets Replacement: adım 7, 1 resimden 1.
    • Press the pin back into the pump head and through the lever. I have done this with a vise, but if you do not care about smashed fingers, you can try to hammer it in
    • Push the pump head back onto the hose and screw down the cover. Done!
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Mark H
728 İtibar
4 adet Kılavuz yazıldı
2 Yorum
Thank you. Shall definitely try it (using a vice)! Cheers!
Ashok Captain - Yanıt
Great work here; thanks for sharing!
Wayne Bollinger - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 31
Her zaman: 6,604
