Giriş
Follow this guide to replace the joystick covers on your Sony DualSense controller.
Note: This guide is for current DualSense controllers with FCC IDs that end with A. Check the back of your controller to verify your model. If yours ends in a 1, it is an early model and there will be internal differences. Follow these guides for the earlier version.
Neye ihtiyacın var
Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
Lift the middle trim over the joysticks to remove it.
Insert the flat end of your spudger into the gap above the L1 button.
Pry the spudger upward to remove the L1 button.
Insert the flat end of your spudger into the gap above the R1 button.
Pry the spudger upward to remove the R1 button.
Use a Phillips screwdriver to remove the two 6.5 mm screws securing the bottom corners of the lower case.
Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
Use your hands to carefully pull the rear case off of the controller.
Lift the battery out of its bracket and reposition it to the right for better access to the battery connector.
Use the pointed end of your spudger to remove the lower microphone from its bracket next to the battery.
Use a Phillips screwdriver to remove the 6.5 mm screw securing the battery bracket.
Grip the right trigger assembly cable with a pair of tweezers or your fingers and disconnect it from the motherboard.
Don't completely remove the ribbon cable yet.
Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the motherboard.
Use a pair of tweezers or your fingers to disconnect the upper microphone from the motherboard.
Use a pair of tweezers or your fingers to disconnect the touchpad cable from the motherboard.
Carefully guide the joysticks through the front case and lift the motherboard out.
Use your fingers to pull the joystick covers straight up and off of their modules.
4 farklı kişi bu kılavuzu tamamladı.
