Ana içeriğe geç
DualSense Controller v2 Light Guide Replacement
Neye ihtiyacın var
  1. DualSense Controller v2 Light Guide Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 1. DualSense Controller v2 Light Guide Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 2.
    • Disconnect and power down the controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
    FixBot'a Sor
    Yorum Ekle
  2. DualSense Controller v2 Light Guide Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 1. DualSense Controller v2 Light Guide Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 2. DualSense Controller v2 Light Guide Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 3.
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
    FixBot'a Sor
    Yorum Ekle
  3. DualSense Controller v2 Light Guide Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 1. DualSense Controller v2 Light Guide Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 2.
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
    FixBot'a Sor
    Yorum Ekle
  4. DualSense Controller v2 Light Guide Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 1. DualSense Controller v2 Light Guide Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 2. DualSense Controller v2 Light Guide Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 3.
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
    FixBot'a Sor
    Yorum Ekle
  5. DualSense Controller v2 Light Guide Replacement, Remove the middle trim: adım 5, 3 resimden 1. DualSense Controller v2 Light Guide Replacement, Remove the middle trim: adım 5, 3 resimden 2. DualSense Controller v2 Light Guide Replacement, Remove the middle trim: adım 5, 3 resimden 3.
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
    • During reassembly, position the middle trim into place and press along all edges to engage the clips securing it to the controller.
    FixBot'a Sor
    Yorum Ekle
  6. DualSense Controller v2 Light Guide Replacement, Remove the L1 button: adım 6, 3 resimden 1. DualSense Controller v2 Light Guide Replacement, Remove the L1 button: adım 6, 3 resimden 2. DualSense Controller v2 Light Guide Replacement, Remove the L1 button: adım 6, 3 resimden 3.
    • Insert the flat end of a spudger into the gap above the L1 button.
    • Cover the button with your thumb to prevent it from ejecting across the room.
    • Pry the spudger upward to remove the L1 button.
    FixBot'a Sor
    Yorum Ekle
  7. DualSense Controller v2 Light Guide Replacement, Remove the R1 button: adım 7, 3 resimden 1. DualSense Controller v2 Light Guide Replacement, Remove the R1 button: adım 7, 3 resimden 2. DualSense Controller v2 Light Guide Replacement, Remove the R1 button: adım 7, 3 resimden 3.
    • Insert the flat end of a spudger into the gap above the R1 button.
    • Pry the spudger upward to remove the R1 button.
    FixBot'a Sor
    Yorum Ekle
  8. DualSense Controller v2 Light Guide Replacement, Remove the case screws: adım 8, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two 6.5 mm screws securing the bottom corners of the lower case.
    FixBot'a Sor
    Yorum Ekle
  9. DualSense Controller v2 Light Guide Replacement: adım 9, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two 6.5 mm screws behind the L1 and R1 buttons.
    FixBot'a Sor
    Yorum Ekle
  10. DualSense Controller v2 Light Guide Replacement, Unclip the rear case: adım 10, 3 resimden 1. DualSense Controller v2 Light Guide Replacement, Unclip the rear case: adım 10, 3 resimden 2. DualSense Controller v2 Light Guide Replacement, Unclip the rear case: adım 10, 3 resimden 3.
    • Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
    FixBot'a Sor
    Yorum Ekle
  11. DualSense Controller v2 Light Guide Replacement, Remove the rear case: adım 11, 2 resimden 1. DualSense Controller v2 Light Guide Replacement, Remove the rear case: adım 11, 2 resimden 2.
    • Use your hands to carefully pull the rear case off of the controller.
    • During reassembly, make sure the red and black vibration motor wires are not pinched between the front and rear case.
    FixBot'a Sor
    Yorum Ekle
  12. DualSense Controller v2 Light Guide Replacement, Reposition the battery: adım 12, 2 resimden 1. DualSense Controller v2 Light Guide Replacement, Reposition the battery: adım 12, 2 resimden 2.
    • Lift the battery out of its bracket and reposition it to the right for better access to the battery connector.
    • Don't strain the battery cables.
    FixBot'a Sor
    Yorum Ekle
  13. DualSense Controller v2 Light Guide Replacement, Disconnect the battery: adım 13, 2 resimden 1. DualSense Controller v2 Light Guide Replacement, Disconnect the battery: adım 13, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Don't pull on the wires to disconnect the battery.
    FixBot'a Sor
    Yorum Ekle
  14. DualSense Controller v2 Light Guide Replacement, Remove the battery: adım 14, 1 resimden 1.
    • Remove the battery.
    FixBot'a Sor
    Yorum Ekle
  15. DualSense Controller v2 Light Guide Replacement, Remove the lower microphone: adım 15, 2 resimden 1. DualSense Controller v2 Light Guide Replacement, Remove the lower microphone: adım 15, 2 resimden 2.
    • Use the pointed end of a spudger to remove the lower microphone from its bracket next to the battery.
    • During reassembly, make sure the end of the microphone's ribbon cable is slotted into the bracket.
    FixBot'a Sor
    Yorum Ekle
  16. DualSense Controller v2 Light Guide Replacement: adım 16, 2 resimden 1. DualSense Controller v2 Light Guide Replacement: adım 16, 2 resimden 2.
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  17. DualSense Controller v2 Light Guide Replacement, Remove the battery bracket: adım 17, 1 resimden 1.
    • Use a Phillips screwdriver to remove the 6.5 mm screw securing the battery bracket.
    FixBot'a Sor
    Yorum Ekle
  18. DualSense Controller v2 Light Guide Replacement: adım 18, 2 resimden 1. DualSense Controller v2 Light Guide Replacement: adım 18, 2 resimden 2.
    • Lift the battery bracket off of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  19. DualSense Controller v2 Light Guide Replacement, Disconnect the right trigger assembly: adım 19, 2 resimden 1. DualSense Controller v2 Light Guide Replacement, Disconnect the right trigger assembly: adım 19, 2 resimden 2.
    • Grip the right trigger assembly cable with a pair of tweezers or your fingers and disconnect it from the motherboard.
    • Use the pull tab to disconnect the cable. Don't pull on the cable itself.
    • Don't completely remove the ribbon cable yet.
    FixBot'a Sor
    Yorum Ekle
  20. DualSense Controller v2 Light Guide Replacement: adım 20, 2 resimden 1. DualSense Controller v2 Light Guide Replacement: adım 20, 2 resimden 2.
    • Grip the right trigger assembly cable with a pair of tweezers or your fingers, and disconnect it from the trigger assembly.
    • Depending on the controller's model, the ribbon cable may block the motherboard from coming loose. If so, remove the cable from the trigger assembly.
    FixBot'a Sor
    Yorum Ekle
  21. DualSense Controller v2 Light Guide Replacement, Disconnect the left trigger assembly: adım 21, 2 resimden 1. DualSense Controller v2 Light Guide Replacement, Disconnect the left trigger assembly: adım 21, 2 resimden 2.
    • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  22. DualSense Controller v2 Light Guide Replacement: adım 22, 2 resimden 1. DualSense Controller v2 Light Guide Replacement: adım 22, 2 resimden 2.
    • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the trigger assembly.
    FixBot'a Sor
    Yorum Ekle
  23. DualSense Controller v2 Light Guide Replacement, Disconnect the upper microphone: adım 23, 2 resimden 1. DualSense Controller v2 Light Guide Replacement, Disconnect the upper microphone: adım 23, 2 resimden 2.
    • Use a pair of tweezers or your fingers to disconnect the upper microphone from the motherboard.
    • If you're not replacing this microphone, don't remove it from the frame.
    FixBot'a Sor
    Yorum Ekle
  24. DualSense Controller v2 Light Guide Replacement, Disconnect the touchpad: adım 24, 2 resimden 1. DualSense Controller v2 Light Guide Replacement, Disconnect the touchpad: adım 24, 2 resimden 2.
    • Use a pair of tweezers or your fingers to disconnect the touchpad cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  25. DualSense Controller v2 Light Guide Replacement, Lift out the motherboard: adım 25, 3 resimden 1. DualSense Controller v2 Light Guide Replacement, Lift out the motherboard: adım 25, 3 resimden 2. DualSense Controller v2 Light Guide Replacement, Lift out the motherboard: adım 25, 3 resimden 3.
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • Don't strain the four soldered wires tethering the motherboard to the vibration motors.
    FixBot'a Sor
    Yorum Ekle
  26. DualSense Controller v2 Light Guide Replacement, Remove the light guide: adım 26, 3 resimden 1. DualSense Controller v2 Light Guide Replacement, Remove the light guide: adım 26, 3 resimden 2. DualSense Controller v2 Light Guide Replacement, Remove the light guide: adım 26, 3 resimden 3.
    • Use the pointed end of your spudger to lift the center of the light guide out of the controller.
    • Remove the light guide.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sam Omiotek
99.125 İtibar
290 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 19
Son 30 gün: 87
Her zaman: 1,683
