Ana içeriğe geç
DualSense Controller v2 Microphone Replacement
Neye ihtiyacın var
  1. DualSense Controller v2 Microphone Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 1. DualSense Controller v2 Microphone Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 2.
    • Disconnect and power down the controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Controller v2 Microphone Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 1. DualSense Controller v2 Microphone Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 2. DualSense Controller v2 Microphone Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 3.
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Controller v2 Microphone Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 1. DualSense Controller v2 Microphone Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 2.
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Controller v2 Microphone Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 1. DualSense Controller v2 Microphone Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 2. DualSense Controller v2 Microphone Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 3.
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Controller v2 Microphone Replacement, Remove the middle trim: adım 5, 3 resimden 1. DualSense Controller v2 Microphone Replacement, Remove the middle trim: adım 5, 3 resimden 2. DualSense Controller v2 Microphone Replacement, Remove the middle trim: adım 5, 3 resimden 3.
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
    • During reassembly, position the middle trim into place and press along all edges to engage the clips securing it to the controller.
  6. DualSense Controller v2 Microphone Replacement, Remove the L1 button: adım 6, 3 resimden 1. DualSense Controller v2 Microphone Replacement, Remove the L1 button: adım 6, 3 resimden 2. DualSense Controller v2 Microphone Replacement, Remove the L1 button: adım 6, 3 resimden 3.
    • Insert the flat end of a spudger into the gap above the L1 button.
    • Cover the button with your thumb to prevent it from ejecting across the room.
    • Pry the spudger upward to remove the L1 button.
  7. DualSense Controller v2 Microphone Replacement, Remove the R1 button: adım 7, 3 resimden 1. DualSense Controller v2 Microphone Replacement, Remove the R1 button: adım 7, 3 resimden 2. DualSense Controller v2 Microphone Replacement, Remove the R1 button: adım 7, 3 resimden 3.
    • Insert the flat end of a spudger into the gap above the R1 button.
    • Pry the spudger upward to remove the R1 button.
  8. DualSense Controller v2 Microphone Replacement, Remove the case screws: adım 8, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two 6.5 mm screws securing the bottom corners of the lower case.
  9. DualSense Controller v2 Microphone Replacement: adım 9, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two 6.5 mm screws behind the L1 and R1 buttons.
  10. DualSense Controller v2 Microphone Replacement, Unclip the rear case: adım 10, 3 resimden 1. DualSense Controller v2 Microphone Replacement, Unclip the rear case: adım 10, 3 resimden 2. DualSense Controller v2 Microphone Replacement, Unclip the rear case: adım 10, 3 resimden 3.
    • Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
  11. DualSense Controller v2 Microphone Replacement, Remove the rear case: adım 11, 2 resimden 1. DualSense Controller v2 Microphone Replacement, Remove the rear case: adım 11, 2 resimden 2.
    • Use your hands to carefully pull the rear case off of the controller.
    • During reassembly, make sure the red and black vibration motor wires are not pinched between the front and rear case.
  12. DualSense Controller v2 Microphone Replacement, Remove the lower microphone: adım 12, 2 resimden 1. DualSense Controller v2 Microphone Replacement, Remove the lower microphone: adım 12, 2 resimden 2.
    • Use the pointed end of your spudger to lift the lower microphone out of its bracket next to the battery.
    • During reassembly, make sure the end of the microphone's ribbon cable is slotted into the bracket.
  13. DualSense Controller v2 Microphone Replacement: adım 13, 2 resimden 1. DualSense Controller v2 Microphone Replacement: adım 13, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of blunt-nose tweezers or your fingers to grip the lower microphone cable by its pull tab and disconnect it from the motherboard.
  14. DualSense Controller v2 Microphone Replacement, Remove the upper microphone: adım 14, 3 resimden 1. DualSense Controller v2 Microphone Replacement, Remove the upper microphone: adım 14, 3 resimden 2. DualSense Controller v2 Microphone Replacement, Remove the upper microphone: adım 14, 3 resimden 3.
    • Use the pointed end of your spudger to lift the upper microphone out of the front case.
    • During reassembly, make sure the upper microphone's ribbon cable is properly slotted and hooked into the front case.
  15. DualSense Controller v2 Microphone Replacement: adım 15, 2 resimden 1. DualSense Controller v2 Microphone Replacement: adım 15, 2 resimden 2.
    • Use a pair of blunt-nose tweezers or your fingers to grip the upper microphone cable by its pull tab and disconnect it from the motherboard.
    • Don't try to remove the microphone yet—it won't fit out this side of the front case.
  16. DualSense Controller v2 Microphone Replacement: adım 16, 2 resimden 1. DualSense Controller v2 Microphone Replacement: adım 16, 2 resimden 2.
    • Use a pair of tweezers or your fingers to remove the upper microphone through the top of the front case.
    • Don't force the cable if you encounter resistance. It may have snagged on the front case.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
93.028 İtibar
290 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where do I buy a replacement microphone? I don’t trust eBay, AliBaba, or AliExpress.
Joey Hurewitz - Yanıt
fixed my stick drift with this guide, though at the cost of having a “stuck” stick when I move it right, works fine; probably won’t stick back my kontrolfreeks they might wear the contact points faster Anyways other than that issue back to a perfect controller warning though as you can see lots of small intricate parts I recommends some stretching because personally my arms were shaking because I was working with small parts and didn’t want to damage anyhthing. Bellowed oaths and persistence later I succeeded.
Benjamin Roman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 42
Son 30 gün: 130
Her zaman: 3,366
