Ana içeriğe geç
DualSense Controller v2 Middle Trim Replacement
Neye ihtiyacın var
  1. DualSense Controller v2 Middle Trim Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 1. DualSense Controller v2 Middle Trim Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 2.
    • Disconnect and power down the controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Controller v2 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 1. DualSense Controller v2 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 2. DualSense Controller v2 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 3.
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Controller v2 Middle Trim Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 1. DualSense Controller v2 Middle Trim Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 2.
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Controller v2 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 1. DualSense Controller v2 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 2. DualSense Controller v2 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 3.
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Controller v2 Middle Trim Replacement, Remove the middle trim: adım 5, 3 resimden 1. DualSense Controller v2 Middle Trim Replacement, Remove the middle trim: adım 5, 3 resimden 2. DualSense Controller v2 Middle Trim Replacement, Remove the middle trim: adım 5, 3 resimden 3.
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
    • During reassembly, position the middle trim into place and press along all edges to engage the clips securing it to the controller.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
93.079 İtibar
290 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 25
Son 30 gün: 69
Her zaman: 1,635
