Ana içeriğe geç
DualSense Controller v2 Middle Trim Replacement
Neye ihtiyacın var
  1. DualSense Controller v2 Middle Trim Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 1. DualSense Controller v2 Middle Trim Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 2.
    • Disconnect and power down the controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
    FixBot'a Sor
  2. DualSense Controller v2 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 1. DualSense Controller v2 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 2. DualSense Controller v2 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 3.
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
    FixBot'a Sor
  3. DualSense Controller v2 Middle Trim Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 1. DualSense Controller v2 Middle Trim Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 2.
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
    FixBot'a Sor
  4. DualSense Controller v2 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 1. DualSense Controller v2 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 2. DualSense Controller v2 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 3.
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
    FixBot'a Sor
  5. DualSense Controller v2 Middle Trim Replacement, Remove the middle trim: adım 5, 3 resimden 1. DualSense Controller v2 Middle Trim Replacement, Remove the middle trim: adım 5, 3 resimden 2. DualSense Controller v2 Middle Trim Replacement, Remove the middle trim: adım 5, 3 resimden 3.
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
    • During reassembly, position the middle trim into place and press along all edges to engage the clips securing it to the controller.
    FixBot'a Sor
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
98.417 İtibar
290 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 102
Her zaman: 2,074
