Ana içeriğe geç
DualShock 3 Rear Cover Replacement
Andrew Bookholt
Andrew Bookholt ve 9 diğer katkıda bulunanlar
En son August 12, 2024 tarihinde güncellendi
2 - 5 dakika
Orta
Use this guide to remove the rear cover of a DualShock 3 controller.
Neye ihtiyacın var
Aletler
  1. DualShock 3 Rear Cover Replacement, Rear Cover: adım 1, 1 resimden 1.
    • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
  2. DualShock 3 Rear Cover Replacement: adım 2, 1 resimden 1.
    • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
  3. DualShock 3 Rear Cover Replacement: adım 3, 2 resimden 1. DualShock 3 Rear Cover Replacement: adım 3, 2 resimden 2.
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
    • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
Sonuç
26 farklı kişi bu kılavuzu tamamladı.
3 Yorum
i have a different dualshock 3 than yours. mine is built in a different way and has a different battery
MasterKlaus Produtions (Swe0b) - Yanıt
Sony did that throughout the Dualshock 3’s production as they found out what would cause them to malfunction and fixed the issue. It should be alright as long as you are able to replace the battery when needed.
Aiodensghost -
iran:
نحوهی تعویض طلق دسته پلی سه هم بذارین. لطفان
مجید محمدی - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 31
Son 30 gün: 128
Her zaman: 24,859
