Giriş
Follow this guide to replace the joystick covers on a Sony Dualshock 4 CHU-ZCT2U PlayStation controller.
Neye ihtiyacın var
Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
Gently pry the rear panel off of the front panel until they become partially separated.
Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
Use a Phillips screwdriver to remove the 6.4 mm-long screw securing the battery bracket.
Pull the right joystick cover straight off the joystick module to remove it.
30 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Are you able to replace the actual joystick with a diffrent one or are we only able to switch out covers?
