Ana içeriğe geç
DualShock 4 CHU-ZCT2U Rear Panel Replacement
Neye ihtiyacın var
  1. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel screws: adım 1, 2 resimden 1. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel screws: adım 1, 2 resimden 2.
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
  2. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Separate the rear panel: adım 2, 2 resimden 1. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Separate the rear panel: adım 2, 2 resimden 2.
    • Four fragile plastic clips hold the panels together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
  3. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Release the plastic clips: adım 3, 3 resimden 1. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Release the plastic clips: adım 3, 3 resimden 2. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Release the plastic clips: adım 3, 3 resimden 3.
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
  4. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel: adım 4, 2 resimden 1. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel: adım 4, 2 resimden 2.
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
  5. DualShock 4 CHU-ZCT2U Rear Panel Replacement: adım 5, 2 resimden 1. DualShock 4 CHU-ZCT2U Rear Panel Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
76.055 İtibar
288 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 21
Son 30 gün: 86
Her zaman: 2,939
