Ana içeriğe geç
Ducky One 2 Mini Cherry MX Switch Replacement
Neye ihtiyacın var
  1. Ducky One 2 Mini Cherry MX Switch Replacement, Cherry MX Switch: adım 1, 1 resimden 1.
    • Unplug and remove the USB Type C connector from the keyboard.
  2. Ducky One 2 Mini Cherry MX Switch Replacement: adım 2, 3 resimden 1. Ducky One 2 Mini Cherry MX Switch Replacement: adım 2, 3 resimden 2. Ducky One 2 Mini Cherry MX Switch Replacement: adım 2, 3 resimden 3.
    • Place the keycap puller over the key you want to remove and push down until you hear a click from the key.
    • Use your opposite hand to hold the keyboard down and pull up with the key puller.
    • Pull the cap with a small amount of force until the keycap is removed. Do this until all keys are removed.
    • Place all caps in a safe location to avoid any missing caps.
  3. Ducky One 2 Mini Cherry MX Switch Replacement: adım 3, 3 resimden 1. Ducky One 2 Mini Cherry MX Switch Replacement: adım 3, 3 resimden 2. Ducky One 2 Mini Cherry MX Switch Replacement: adım 3, 3 resimden 3.
    • Once all caps are separated from the keyboard, you should find six Phillips #00 screws.
    • Use the Phillips #00 screwdriver to remove all six 2.00 mm screws from the board and place them somewhere safe.
    • Separate the board from the base.
    • Remember to clean out the base of the keyboard.
  4. Ducky One 2 Mini Cherry MX Switch Replacement: adım 4, 3 resimden 1. Ducky One 2 Mini Cherry MX Switch Replacement: adım 4, 3 resimden 2. Ducky One 2 Mini Cherry MX Switch Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Desoldering Pump
    $3.99
    • Flip the board over and you will notice two soldered pins near each letter on the keyboard.
    • Hold the soldering iron on the pins for a few seconds and remove with the de-soldering pump.
    • Once both the pins are clear of solder, the pins should move freely in the slots.
    • When heating the soldered pins, do not let the iron touch the board to avoid any damage.
    • Do Not Touch the neck of the solder iron when plugged in to avoid any harm.
  5. Ducky One 2 Mini Cherry MX Switch Replacement: adım 5, 3 resimden 1. Ducky One 2 Mini Cherry MX Switch Replacement: adım 5, 3 resimden 2. Ducky One 2 Mini Cherry MX Switch Replacement: adım 5, 3 resimden 3.
    • Once both pins are removed, flip the board over again.
    • Use the switch puller, place the tool vertically over the switch. You will notice two tabs on the switches, push the tabs inwards.
    • With the tabs pushed in, pull the switch puller up and the switch should separate from the board.
    • The switch puller should be vertical because the two tabs on the switch are placed on the top and bottom.
  6. Ducky One 2 Mini Cherry MX Switch Replacement: adım 6, 3 resimden 1. Ducky One 2 Mini Cherry MX Switch Replacement: adım 6, 3 resimden 2. Ducky One 2 Mini Cherry MX Switch Replacement: adım 6, 3 resimden 3.
    • To place the new switch into the board, line up the two pins on the switch with the slots on the board and push down on it until you hear a "click" sound.
    • Repeat steps 4-6 until all switches are replaced.
    • Please keep the switches safe and do not let the pins bend to avoid damage.
  7. Ducky One 2 Mini Cherry MX Switch Replacement: adım 7, 3 resimden 1. Ducky One 2 Mini Cherry MX Switch Replacement: adım 7, 3 resimden 2. Ducky One 2 Mini Cherry MX Switch Replacement: adım 7, 3 resimden 3.
    • Flip the board over and you will see the two pins inside the slots for the letters.
    • Use the soldering iron to solder the pins to the slots on the board until the pins are covered in solder.
    • Repeat for the second pin on the switch and until all the switches are soldered to the board.
    • Once all switches are replaced repeat Steps 1 and 2 in reverse order.
Sonuç
You should now have the same keyboard you originally had but with new switches! Thank you for following my guide and I hope you are satisfied with your new keyboard.
4 farklı kişi bu kılavuzu tamamladı.
Adnan Khan
289 İtibar
1 Kılavuz yazıldı
5Kılavuz Yorumları
Can you add new switches and not solder them in ? to make them easily servicable...
Marius Tamosiunas - Yanıt
Soldering is required. It acts as glue but also completes the electrical circuit between the switch and the rest of the board. Without soldering, no key presses from the switch will be detected
Jimmy Chang -
Hey, can you please confirm what type of switches are used, i am confused as there are many types of switches, eg. SMD, RGB, 5 pin, 3 pin, etc. Also, can i add any hot swap adapters to the board to make the kayboard hot swappable? I've seen a bunch of these pins online and was wondering if they could be used on this keyboard.
PS: I have a Ducky One 2 SF, and I'm assuming your guide on the Ducky One 2 Mini should work for my keyboard too.
Swayam Khanna - Yanıt
Are you able to replace the switches on the spacebar?
Fire Aussie - Yanıt
Just did it on the spacebar (switches are the same on all keys), worked like a charm and I'm a total newbie (it was my 1st solder ever). I used Cherry MX RGB Speed Silver you can find on amzn by 10 or more.
Mathieu Delafosse -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 56
Son 30 gün: 302
Her zaman: 26,360
