Ana içeriğe geç
Dymo LabelManager 280 Screen Replacement
Neye ihtiyacın var
    1. Dymo LabelManager 280 Screen Replacement, Rear Case: adım 1, 2 resimden 1. Dymo LabelManager 280 Screen Replacement, Rear Case: adım 1, 2 resimden 2.
      • Remove battery.
      • Remove the label cassette.
      FixBot'a Sor
      Yorum Ekle
    2. Dymo LabelManager 280 Screen Replacement: adım 2, 2 resimden 1. Dymo LabelManager 280 Screen Replacement: adım 2, 2 resimden 2.
      • Remove the two rubber feets
      • Remove the 6 screws in the indicated places. These particular screws are 2mm x 8mm Phillips #0 head
      FixBot'a Sor
      Yorum Ekle
    3. Dymo LabelManager 280 Screen Replacement: adım 3, 2 resimden 1. Dymo LabelManager 280 Screen Replacement: adım 3, 2 resimden 2.
      • Use the spudger to take apart the device by insterting it as shown in the picture and twisting it. This should be done all around the device to ensure the two parts split correctly.
      • The keys/buttons highlighted in the second picture fall out easily so be careful. Keep device faced down in order to keep them from falling.
      FixBot'a Sor
      Yorum Ekle
    1. Dymo LabelManager 280 Screen Replacement, Screen: adım 4, 1 resimden 1.
      • Further remove the 2 screws (1.2mm X 4mm Phillips #0 head).
      FixBot'a Sor
      Yorum Ekle
    2. Dymo LabelManager 280 Screen Replacement: adım 5, 2 resimden 1. Dymo LabelManager 280 Screen Replacement: adım 5, 2 resimden 2.
      • Detach the ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    3. Dymo LabelManager 280 Screen Replacement: adım 6, 1 resimden 1.
      • Remove the screen.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Steven Nguyen
431 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-5, Eyestone Spring 2016 USF Tampa, Team 6-5, Eyestone Spring 2016 üyesi
USFT-EYESTONE-S16S6G5
3 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
Hi, thak you for the tutorial, it seems pretty simple. Do you know where to find the LCD screen, or whats the specs, maybe I can find it at AliExpress.
Jacques Maltais - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 58
Her zaman: 4,845
