Ana içeriğe geç
Dyson V8 Animal Battery Replacement
Neye ihtiyacın var
    1. Dyson V8 Animal Battery Replacement, Bin: adım 1, 2 resimden 1. Dyson V8 Animal Battery Replacement, Bin: adım 1, 2 resimden 2.
      • Push the red button and slide the connecting shaft off.
      • The shaft must be held from moving when disconnecting from the motor.
      FixBot'a Sor
      Yorum Ekle
    2. Dyson V8 Animal Battery Replacement: adım 2, 3 resimden 1. Dyson V8 Animal Battery Replacement: adım 2, 3 resimden 2. Dyson V8 Animal Battery Replacement: adım 2, 3 resimden 3.
      • Pull up on the red tab and continue to slide the motor completely up.
      • The dust bin will open on the bottom.
      FixBot'a Sor
      Yorum Ekle
    3. Dyson V8 Animal Battery Replacement: adım 3, 2 resimden 1. Dyson V8 Animal Battery Replacement: adım 3, 2 resimden 2.
      • Push the red tab down.
      • Pull the dust bin out from the handle head.
      FixBot'a Sor
      Yorum Ekle
    1. Dyson V8 Animal Battery Replacement, Battery: adım 4, 2 resimden 1. Dyson V8 Animal Battery Replacement, Battery: adım 4, 2 resimden 2.
      • Push down on the red tab.
      FixBot'a Sor
      Yorum Ekle
    2. Dyson V8 Animal Battery Replacement: adım 5, 2 resimden 1. Dyson V8 Animal Battery Replacement: adım 5, 2 resimden 2.
      • Push down on the red tab on the other side.
      • Pull the motor away from the handle.
      • You may need to hold down the handle while sliding the motor off.
      FixBot'a Sor
      Yorum Ekle
    3. Dyson V8 Animal Battery Replacement: adım 6, 2 resimden 1. Dyson V8 Animal Battery Replacement: adım 6, 2 resimden 2.
      • Use a Phillips #0 screwdriver to remove two 18 mm screws on the bottom of the battery.
      FixBot'a Sor
      Yorum Ekle
    4. Dyson V8 Animal Battery Replacement: adım 7, 1 resimden 1.
      • Use a Phillips #0 screwdriver to remove one 18 mm screw on the back of the handle.
      FixBot'a Sor
      Yorum Ekle
    5. Dyson V8 Animal Battery Replacement: adım 8, 2 resimden 1. Dyson V8 Animal Battery Replacement: adım 8, 2 resimden 2.
      • Slide the battery out from handle.
      • The handle must be held from moving while sliding the battery out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
AJ McLean-Scholz
888 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G1, White Winter 2020 Cal Poly, Team S19-G1, White Winter 2020 üyesi
CPSU-WHITE-W20S19G1
4 Üyeler
18 adet Kılavuz yazıldı
9Kılavuz Yorumları
Replacement Vacuum Cleaner Batteries for Dyson V8 Animal
Battery Type:   Li-ion
Voltage:   21.6V
Capacity:   4000mAh
Color:   Grey
Weight:   770.26g
Dimensions: 145.00 x 90.10 x 115.90mm
If you intereted in this battery, please view more info on http://www.drillbattery.com.au/orderbatt...
Drillbatterycomau - Yanıt Paylaş
Thankyou! I'll be able to replace the battery soon.
Olivia Swift - Yanıt Paylaş
This worked for the V7 Animal model just fine. Very easy and clear, thank you!
Katie - Yanıt Paylaş
Thank you. These instructions just helped me to replace the worn out battery on our V8 Animal in 5 minutes! Now it's humming along again with 3 blue bars. Great! (Note: I was concerned I might strip the screw head but I just pressed harder while turning and the screwdriver did not slip. Then I saw that the replacement battery came with four new replacement screws. So, it's all good.)
Neill Graham - Yanıt Paylaş
I have a stripped screw that won't extract. I have already drilled the hole ho so now no screwdriver will work. Any suggestions?
christina - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 65
Son 30 gün: 350
Her zaman: 13,816
