Ana içeriğe geç
EBK340  Powerhead  Replacement
FolsomMaids Office
FolsomMaids Office ve 2 diğer katkıda bulunanlar
En son August 6, 2024 tarihinde güncellendi
5 - 10 dakika
Orta
Topluluk-Katkılı Kılavuz
It is very annoying to carry around the powerhead when it does not click together. Usually this results from wear on the plastic neck joint, which can be replaced.
Neye ihtiyacın var
  1. EBK340  Powerhead  Replacement, Remove Outer Cover: adım 1, 1 resimden 1.
    • Position the device so brushes are upwards and visible
    • Unscrew the 6 outer screws. 2 on the edge of the brush crevice, and 4 nearer to the wheels.
    • Turn over the device.
    • Pull the cover off gently.
  2. EBK340  Powerhead  Replacement, Remove Inner Cover: adım 2, 1 resimden 1.
    • Unscrew the 2 screws indicated, one visible, the other within a deep hole
    • Gently pull off the cover. Careful not to torque the plastic teeth shown in orange.
  3. EBK340  Powerhead  Replacement, Replace Neck Joint: adım 3, 2 resimden 1. EBK340  Powerhead  Replacement, Replace Neck Joint: adım 3, 2 resimden 2.
    • Gently lift the two LED lights upwards and away for the moment.
    • Gently lift out the defective neck joint.
    • Slide in the replacement joint.
    • Replace the lights into the molded corners that hold their board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
FolsomMaids Office
167 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 95
