Ana içeriğe geç
ECAM 2XXX test mode
    1. ECAM 2XXX test mode, ECAM 2XXX test mode: adım 1, 3 resimden 1. ECAM 2XXX test mode, ECAM 2XXX test mode: adım 1, 3 resimden 2. ECAM 2XXX test mode, ECAM 2XXX test mode: adım 1, 3 resimden 3.
      • Unplug the power cord. The switch on the back must be turned on. There must be water in the tank and all trays must be inserted.
      • Press and hold the "one cup" and "water" buttons at the same time.
      • Plug the connector back in and release the buttons.
      • The indication of the test mode appears on the display.
      FixBot'a Sor
      Yorum Ekle
    2. ECAM 2XXX test mode: adım 2, 1 resimden 1.
      • You now can test various important components; the corresponding message appears on the display:
      • Pressing the rotary switch in the middle activates the solenoid valve 2 for the steam. (Ev2, at the top of the machine) You should hear it click.
      FixBot'a Sor
      Yorum Ekle
    3. ECAM 2XXX test mode: adım 3, 1 resimden 1.
      • The functions for the square buttons are:
      • Both solenoid valves switch.
      • Solenoid valve 1 for the coffee (Ev1, at the bottom of the machine) switches.
      • The heater for the coffee gets warm.
      • Motor moves to the end positions and then reverses as long as the button is pressed.
      • The grinder is running.
      • The pump is running.
      • The cappuccino button at the bottom left switches the steam heater.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Reverse the steps to reassemble your device.
2 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
VauWeh
339.078 İtibar
311 adet Kılavuz yazıldı
Ekip
Repair is War on Entropy Repair is War on Entropy üyesi
Community
39 Üyeler
2.749 adet Kılavuz yazıldı
2Kılavuz Yorumları
Handleiding gaat niet over machine met knoppen. Ik heb eentje met knoppen zonder display. Wat nu?
Sietske - Yanıt Paylaş
ich habe eine ECAM22.366 Magnifica S Cappucino. da funktioniert es so nicht. Im Display steht weiterhin "Brühgruppe einsetzen"
Christian - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 87
Son 30 gün: 388
Her zaman: 7,938
