Giriş
In this guide, you will learn how to replace the motor on an Eachine Tyro99 racing drone.
The magnets in the motor can attract metal shavings and other FOD, and if the motors continue running in this state, they can break. Here’s how you can fix it!
You’ll need a soldering iron, solder, a 1.5mm allen (hex) wrench, electrical pliers, and a utility or hobby knife.
The steps will guide you through removing the defective motor. Step 5 requires that you solder several wires together. From there, you’ll install the new motor.
Remember to remove the propellers before testing any of the motors.
Neye ihtiyacın var
Your new motor should be correctly installed now! Be sure to initially test it with the propeller detached; I’ve injured myself by carelessly testing this very drone.
