Ana içeriğe geç
EasySMX ESM-9100 Home Button Replacement
Neye ihtiyacın var
  1. EasySMX ESM-9100 Home Button Replacement, Bottom Case: adım 1, 1 resimden 1.
    • Place the controller face down on a solid surface.
    • Use a Phillips #00 screwdriver to remove the seven 10 mm screws from the back cover.
    • The order does not matter.
  2. EasySMX ESM-9100 Home Button Replacement: adım 2, 3 resimden 1. EasySMX ESM-9100 Home Button Replacement: adım 2, 3 resimden 2. EasySMX ESM-9100 Home Button Replacement: adım 2, 3 resimden 3.
    • Use the iFixit opening tool to pry off the back cover and remove it to reveal the internal components.
    • Place the cover off to the side, then grab the circuit board and gently remove it from the front cover.
    • Be careful when removing the back cover, the components in this controller are loosely attached and can fall out easily.
  3. EasySMX ESM-9100 Home Button Replacement, Home Button: adım 3, 3 resimden 1. EasySMX ESM-9100 Home Button Replacement, Home Button: adım 3, 3 resimden 2. EasySMX ESM-9100 Home Button Replacement, Home Button: adım 3, 3 resimden 3.
    • Press on the home button from the front of the top cover to pop it through.
    • Gently remove it from the backside of the top cover.
    • When replacing the home button make sure to align the tabs on the button with the grooves in the socket.
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
Alex Vala
746 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-4, Shaddix Spring 2024 UMass Dartmouth, Team 4-4, Shaddix Spring 2024 üyesi
UMASSD-SHADDIX-S24S4G4
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 55
