Ana içeriğe geç
EasySMX ESM-9100 Navigation Buttons Replacement
Neye ihtiyacın var
  1. EasySMX ESM-9100 Navigation Buttons Replacement, Bottom Case: adım 1, 1 resimden 1.
    • Place the controller face down on a solid surface.
    • Use a Phillips #00 screwdriver to remove the seven 10 mm screws from the back cover.
    • The order does not matter.
    FixBot'a Sor
    Yorum Ekle
  2. EasySMX ESM-9100 Navigation Buttons Replacement: adım 2, 3 resimden 1. EasySMX ESM-9100 Navigation Buttons Replacement: adım 2, 3 resimden 2. EasySMX ESM-9100 Navigation Buttons Replacement: adım 2, 3 resimden 3.
    • Use the iFixit opening tool to pry off the back cover and remove it to reveal the internal components.
    • Place the cover off to the side, then grab the circuit board and gently remove it from the front cover.
    • Be careful when removing the back cover, the components in this controller are loosely attached and can fall out easily.
    FixBot'a Sor
    Yorum Ekle
  3. EasySMX ESM-9100 Navigation Buttons Replacement, Navigation Buttons: adım 3, 2 resimden 1. EasySMX ESM-9100 Navigation Buttons Replacement, Navigation Buttons: adım 3, 2 resimden 2.
    • Pull the back button out of the front cover.
    • Keep the controller face down while doing this to prevent the other buttons from falling out.
    FixBot'a Sor
    Yorum Ekle
  4. EasySMX ESM-9100 Navigation Buttons Replacement: adım 4, 2 resimden 1. EasySMX ESM-9100 Navigation Buttons Replacement: adım 4, 2 resimden 2.
    • Pull the start button out of the front cover.
    FixBot'a Sor
    Yorum Ekle
  5. EasySMX ESM-9100 Navigation Buttons Replacement: adım 5, 2 resimden 1. EasySMX ESM-9100 Navigation Buttons Replacement: adım 5, 2 resimden 2.
    • Pull the turbo button out from the front cover carefully.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
Alex Vala
837 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-4, Shaddix Spring 2024 UMass Dartmouth, Team 4-4, Shaddix Spring 2024 üyesi
UMASSD-SHADDIX-S24S4G4
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 34
Her zaman: 464
