Ana içeriğe geç
EasySMX X15 Main Board Replacement
Neye ihtiyacın var
  1. EasySMX X15 Main Board Replacement, Bottom Casing: adım 1, 2 resimden 1. EasySMX X15 Main Board Replacement, Bottom Casing: adım 1, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the four 9 mm screws from the bottom of the EasySMX X15.
    • Use an opening tool to gently pry between the seams of the controller to separate the lower and upper casings.
    • Be gentle when separating the lower casing from the upper casing to avoid breaking any of the plastic snap tabs.
    FixBot'a Sor
    Yorum Ekle
  2. EasySMX X15 Main Board Replacement, Battery: adım 2, 3 resimden 1. EasySMX X15 Main Board Replacement, Battery: adım 2, 3 resimden 2. EasySMX X15 Main Board Replacement, Battery: adım 2, 3 resimden 3.
    • Push on alternating sides of the connector to disconnect the red battery cable from the board.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • Pull from the tab, not the cables, to avoid damaging them.
    FixBot'a Sor
    Yorum Ekle
  3. EasySMX X15 Main Board Replacement: adım 3, 1 resimden 1.
    • Use a spudger to pry the battery loose from the controller.
    • The battery is glued onto the control board, so it may take a bit of work to release it from the adhesive.
    • Remove the battery.
    • Don't bend or pierce the battery. If the battery is swollen, follow the guidelines outlined in this article.
    FixBot'a Sor
    Yorum Ekle
  4. EasySMX X15 Main Board Replacement, Main Board: adım 4, 1 resimden 1.
    • Disconnect the vibration motor cables from the connectors on the circuit board.
    • Use a Phillips #00 screwdriver to remove six, 6mm screws from the board.
    FixBot'a Sor
    Yorum Ekle
  5. EasySMX X15 Main Board Replacement: adım 5, 1 resimden 1.
    • Gently lift the board away from the upper casing, maneuvering it around the triggers by lifting it from the bottom, away from the upper casing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
ShawnDetiveaux
646 İtibar
4 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 37
Her zaman: 403
