Ana içeriğe geç
Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement
Neye ihtiyacın var
  1. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Disconnect the spark plug wire: adım 1, 3 resimden 1. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Disconnect the spark plug wire: adım 1, 3 resimden 2. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Disconnect the spark plug wire: adım 1, 3 resimden 3.
    • Before you begin, ensure that the engine is powered down and cool to the touch.
    • Grip the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Disconnect the control cables: adım 2, 2 resimden 1. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Disconnect the control cables: adım 2, 2 resimden 2.
    • Unclip the throttle cable routing clip from the main shaft.
  3. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: adım 3, 3 resimden 1. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: adım 3, 3 resimden 2. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: adım 3, 3 resimden 3.
    • Grip both ends of one of the control cable bullet connectors and pull to disconnect it.
    • Repeat to disconnect the second control cable connector.
    • These connectors are interchangeable.
  4. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Remove the muffler cover: adım 4, 2 resimden 1. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Remove the muffler cover: adım 4, 2 resimden 2.
    • This Echo device has an included multi-tool with a T30 Torx screwdriver, but any T30 Torx driver is compatible.
    • Use a T30 Torx driver to remove the two screws securing the muffler cover.
  5. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: adım 5, 3 resimden 1. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: adım 5, 3 resimden 2. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: adım 5, 3 resimden 3.
    • Lift the muffler cover up and pivot it on its top edge to unlatch it from the engine cover.
    • Remove the muffler cover.
  6. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Remove the engine cover: adım 6, 2 resimden 1. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Remove the engine cover: adım 6, 2 resimden 2.
    • Use a T30 Torx driver to remove the two screws securing the engine cover.
  7. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: adım 7, 2 resimden 1. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: adım 7, 2 resimden 2.
    • Lift the engine cover straight up to remove it.
  8. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Remove the fan cover: adım 8, 1 resimden 1.
    • Use a T30 Torx driver to remove the two screws securing the fan cover.
  9. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: adım 9, 2 resimden 1. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: adım 9, 2 resimden 2.
    • Pull the fan cover away from the motor assembly.
  10. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Reassembly tip: adım 10, 2 resimden 1. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Reassembly tip: adım 10, 2 resimden 2.
    • During reassembly:
    • Reroute the two control cables through the opening on the fan cover.
    • Lay the cables into their slot on the clutch cover.
  11. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Separate the shaft from the engine assembly: adım 11, 1 resimden 1.
    • Use a T30 Torx driver to loosen, but not remove, the collar bolt securing the main shaft to the engine assembly.
  12. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: adım 12, 3 resimden 1. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: adım 12, 3 resimden 2. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: adım 12, 3 resimden 3.
    • Grip the engine assembly and pull to remove it from the main shaft.
    • With the engine assembly removed, take care to not put any strain on the still-connected throttle cable.
  13. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Remove the clutch cover: adım 13, 1 resimden 1.
    • Use a T30 Torx driver to remove the two screws securing the clutch cover.
  14. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: adım 14, 2 resimden 1. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: adım 14, 2 resimden 2.
    • Remove the clutch cover.
  15. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement, Remove the clutch assembly: adım 15, 1 resimden 1.
    • Use a 1/2 inch socket to remove the two 12 mm-long bolts and four accompanying washers securing the clutch assembly.
    • Note that the larger washer goes underneath the clutch assembly and the small washer goes above.
    • Ensure that the clutch assembly is reinstalled arrow side up.
  16. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: adım 16, 2 resimden 1. Echo Brushcutter SRM2620U 2017 Clutch Assembly Replacement: adım 16, 2 resimden 2.
    • Remove the clutch assembly.
Sonuç
Carsten Frauenheim
135.750 İtibar
371 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.454 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 22
Her zaman: 1,086
