Ana içeriğe geç
Echo Chain Saw CS590 2019 Oil System Replacement
Neye ihtiyacın var
  1. Echo Chain Saw CS590 2019 Oil System Replacement, Turn off the chainsaw: adım 1, 2 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Turn off the chainsaw: adım 1, 2 resimden 2.
    • Make sure you have the ignition switch turned off before starting your repair.
    • The chainsaw should be cool to the touch before continuing.
  2. Echo Chain Saw CS590 2019 Oil System Replacement, Loosen the air filter cover: adım 2, 2 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Loosen the air filter cover: adım 2, 2 resimden 2.
    • Use your fingers to loosen the air filter cover knob.
  3. Echo Chain Saw CS590 2019 Oil System Replacement: adım 3, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement: adım 3, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement: adım 3, 3 resimden 3.
    • Remove the air filter cover.
  4. Echo Chain Saw CS590 2019 Oil System Replacement, Disconnect the spark plug: adım 4, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Disconnect the spark plug: adım 4, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Disconnect the spark plug: adım 4, 3 resimden 3.
    • Use your fingers to pull up and disconnect the spark plug boot.
  5. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the air filter: adım 5, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the air filter: adım 5, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the air filter: adım 5, 3 resimden 3.
    • To minimize debris entering the intake, pull the choke shut before continuing.
    • During reassembly, clean the air filter with compressed air or with light brushing before reinstalling it.
  6. Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the front handle: adım 6, 2 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the front handle: adım 6, 2 resimden 2.
    • Use a T25 Torx screwdriver to remove the five screws securing the front handle to the bottom and right side of the device:
    • Four 24 mm-long screws
    • One 25 mm-long screw
  7. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the front handle: adım 7, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the front handle: adım 7, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the front handle: adım 7, 3 resimden 3.
    • Pull the handle toward the rear of the device to remove it.
  8. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the sprocket guard: adım 8, 2 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the sprocket guard: adım 8, 2 resimden 2.
    • Use a 13 mm wrench to remove the two nuts securing the sprocket guard.
  9. Echo Chain Saw CS590 2019 Oil System Replacement: adım 9, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement: adım 9, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement: adım 9, 3 resimden 3.
    • Remove the sprocket guard.
  10. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the guide bar: adım 10, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the guide bar: adım 10, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the guide bar: adım 10, 3 resimden 3.
    • Push the guide bar towards the back of the device to create slack in the saw chain.
    • Pull the guide bar away from the device to separate the saw chain from the clutch drum.
    • Remove the guide bar.
  11. Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the front hand guard: adım 11, 2 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the front hand guard: adım 11, 2 resimden 2.
    • Make sure the front hand guard is in the unlocked position before continuing.
    • Use a T25 Torx screwdriver to remove the two 20 mm screws securing the front hand guard.
  12. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the front hand guard: adım 12, 2 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the front hand guard: adım 12, 2 resimden 2.
    • Pull the front hand guard toward the rear of the device to remove it.
  13. Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the engine cover: adım 13, 2 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the engine cover: adım 13, 2 resimden 2.
    • Use a T25 Torx screwdriver to remove the three 20 mm screws securing the engine cover.
  14. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the engine cover: adım 14, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the engine cover: adım 14, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the engine cover: adım 14, 3 resimden 3.
    • Pull the engine cover straight off the device to remove it.
  15. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil cap: adım 15, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil cap: adım 15, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil cap: adım 15, 3 resimden 3.
    • Use your fingers to loosen and remove the oil cap.
  16. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil filter: adım 16, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil filter: adım 16, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil filter: adım 16, 3 resimden 3.
    • Use a flathead screwdriver, or your fingers, to remove the oil filter from its recess in the fuel assembly.
  17. Echo Chain Saw CS590 2019 Oil System Replacement: adım 17, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement: adım 17, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement: adım 17, 3 resimden 3.
    • Pull on the oil filter to separate it from the fuel pipe.
  18. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the inner guide plate: adım 18, 2 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the inner guide plate: adım 18, 2 resimden 2.
    • Insert the edge of a screwdriver between the inner guide plate and the chassis.
    • Pry up with the screwdriver to initially separate the plate.
    • Slide the plate out of its two bolts to remove it.
  19. Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the brake cover: adım 19, 2 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the brake cover: adım 19, 2 resimden 2.
    • Use a T25 Torx screwdriver to remove the four screws securing the brake cover:
    • Three 20 mm-long screws
    • One 16 mm-long screw
  20. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the brake cover: adım 20, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the brake cover: adım 20, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the brake cover: adım 20, 3 resimden 3.
    • Pull the brake cover straight off the clutch drum to remove it.
  21. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the E-ring: adım 21, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the E-ring: adım 21, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the E-ring: adım 21, 3 resimden 3.
    • Use E-ring pliers, or a flathead screwdriver, to remove the E-ring on the clutch drum.
  22. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the washer: adım 22, 2 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the washer: adım 22, 2 resimden 2.
    • Use your fingers to pull the washer straight out of its housing to remove it.
  23. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the clutch drum: adım 23, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the clutch drum: adım 23, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the clutch drum: adım 23, 3 resimden 3.
    • Pull the clutch drum straight out of its recess to remove it.
    • The needle bearing should come out with the clutch drum. Make sure bearing is reinserted before reinstalling the clutch drum.
  24. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the spark plug: adım 24, 2 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the spark plug: adım 24, 2 resimden 2.
    • Use a spark plug socket to loosen and remove the spark plug.
  25. Echo Chain Saw CS590 2019 Oil System Replacement, Insert a rope: adım 25, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Insert a rope: adım 25, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Insert a rope: adım 25, 3 resimden 3.
    • Feed a piston stopping cord or rope through the cylinder head into the combustion chamber until the crankshaft can no longer rotate.
    • Do not insert the entire cord into the combustion chamber.
  26. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the clutch assembly: adım 26, 2 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the clutch assembly: adım 26, 2 resimden 2.
    • Use a clutch removal tool and a wrench to loosen the clutch assembly.
    • Rotate the wrench clockwise instead of clockwise.
  27. Echo Chain Saw CS590 2019 Oil System Replacement: adım 27, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement: adım 27, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement: adım 27, 3 resimden 3.
    • Use your fingers to loosen the clutch assembly and remove it from the crankshaft.
  28. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the clutch plate: adım 28, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the clutch plate: adım 28, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the clutch plate: adım 28, 3 resimden 3.
    • Use your fingers to pull the clutch plate straight off of the crankshaft and remove it.
  29. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the collar: adım 29, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the collar: adım 29, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the collar: adım 29, 3 resimden 3.
    • Use pliers, or your fingers, to pull the collar off of the crankshaft and remove it.
  30. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the worm gear: adım 30, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the worm gear: adım 30, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the worm gear: adım 30, 3 resimden 3.
    • Use pliers to pull the worm gear straight out its housing to remove it.
  31. Echo Chain Saw CS590 2019 Oil System Replacement, Disconnect the oiler assembly: adım 31, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Disconnect the oiler assembly: adım 31, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Disconnect the oiler assembly: adım 31, 3 resimden 3.
    • Use your fingers, or a flathead screwdriver, to disconnect the top oil pipe from the oiler assembly.
    • Only use a flathead screwdriver if the fuel pipe is too tight. The sharp edge could cause a split in the pipe.
  32. Echo Chain Saw CS590 2019 Oil System Replacement: adım 32, 2 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement: adım 32, 2 resimden 2.
    • Use your fingers, or a flathead screwdriver, to disconnect the right oil pipe from the oiler assembly.
  33. Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the oiler assembly: adım 33, 2 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the oiler assembly: adım 33, 2 resimden 2.
    • Use a T25 Torx screwdriver to remove the two 15 mm screws securing the oiler assembly.
  34. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oiler assembly: adım 34, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oiler assembly: adım 34, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oiler assembly: adım 34, 3 resimden 3.
    • Use pliers, or your fingers, to pull the oiler assembly straight out its housing to remove it.
  35. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the washer: adım 35, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the washer: adım 35, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the washer: adım 35, 3 resimden 3.
    • Use pliers, or your fingers, to pull the washer off of the crankshaft and remove it.
  36. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil outlet port: adım 36, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil outlet port: adım 36, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil outlet port: adım 36, 3 resimden 3.
    • Use a flathead screwdriver to pry the oil outlet port out its recess in the chassis.
    • Remove the oil outlet port.
  37. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil pipe: adım 37, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil pipe: adım 37, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil pipe: adım 37, 3 resimden 3.
    • Thread the oil pipe through the oil cap recess to remove it.
  38. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the grommet: adım 38, 3 resimden 1. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the grommet: adım 38, 3 resimden 2. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the grommet: adım 38, 3 resimden 3.
    • Use a pick tool to remove the grommet next to the clutch assembly's recess.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
127.681 İtibar
592 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
141 Üyeler
17.895 adet Kılavuz yazıldı
3 Yorum
***Step 36*** Remove the retaining ring . Is there a reason to remove, unless you're doing a complete teardown?
VAL - Yanıt
Hi there.
You're right! That was a left over from a different procedure, and I'll remove the step. Thank you!
Alex Diaz-Kokaisl -
Is there a torque value for the clutch? If so, what is it?
SHANE - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 29
Son 30 gün: 162
Her zaman: 2,318
