Ana içeriğe geç
Eclipse 180G2 MP3 Video Player speaker Replacement
Neye ihtiyacın var
  1. Eclipse 180G2 MP3 Video Player speaker Replacement, Outer Case: adım 1, 2 resimden 1. Eclipse 180G2 MP3 Video Player speaker Replacement, Outer Case: adım 1, 2 resimden 2.
    • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
    • Use a spudger to remove the plastic plate from the bottom of the player.
  2. Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: adım 2, 3 resimden 1. Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: adım 2, 3 resimden 2. Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: adım 2, 3 resimden 3.
    • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
    • Use the spudger to push the USB port on the bottom of the device inward.
    • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
  3. Eclipse 180G2 MP3 Video Player speaker Replacement, Internal Speaker: adım 3, 2 resimden 1. Eclipse 180G2 MP3 Video Player speaker Replacement, Internal Speaker: adım 3, 2 resimden 2.
    • Identify the speaker. Pull the speaker away from the device so that wires are exposed.
    • Using a wire cutter, sever the red and black cables that are connecting the speaker to the circuit board.
    • You will need to solder the new speaker wires to connect it to the device.
Sonuç
  • To reassemble your device after completion of replacement, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Jesse Minor
662 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Tanski Winter 2015 USF Tampa, Team 1-4, Tanski Winter 2015 üyesi
USFT-TANSKI-W15S1G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 859
