Ana içeriğe geç
Ecovacs DEEBOT D35 Battery Replacement
Neye ihtiyacın var
  1. Ecovacs DEEBOT D35 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Press and hold the tabs on both sides of the battery.
  2. Ecovacs DEEBOT D35 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the battery from the Deebot
  3. Ecovacs DEEBOT D35 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the screw attaching the battery housing.
  4. Ecovacs DEEBOT D35 Battery Replacement: adım 4, 1 resimden 1.
    • Inert the new battery casing into the housing.
    • Replace the screw attaching the housing.
    • Replace the batter housing in the Deebot.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Brian
475 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-2, Eyestone Spring 2017 USF Tampa, Team 12-2, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S12G2
4 Üyeler
4 adet Kılavuz yazıldı
7Kılavuz Yorumları
How do you actually take the battery pack out of the casing?
Jonathan A - Yanıt
Where can i find a replacement battery for deebot model d35
Travis neas - Yanıt
JonathanA - you don't, it comes complete in the casing and can not be opened.
Kate Oe - Yanıt
But where can we buy a replacement battery for deebot 35?
Kay Pott - Yanıt
Where can i buy a replacement battery for D35
Terry Martin
Terry Martin -
where can you buy battery for d35
glynn wild - Yanıt
I cannot get the battery separated from its joint to insert the replacement battery on my n79s. My fingers are raw from squeezing and pulling.
Nem - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 53
Her zaman: 14,419
